chrisvw
After >4000 relatively troublefree miles, I'm having a bit of trouble with my bike and thought I'd ask for help before I start replacing parts. Here's what I have and the symptoms:
Crystalyte 5303 with Crystalyte 4840 controller (48V, 40A). 48V LIPO pack.
Problem: Intermittenly, the motor will stop working. I can get about 1 second of thrust, but the motor "growls" and vibrates. It sounds like the normal cogging noise the motor would make but about 10 times louder. The vibration is very noticeable. If I keep on the throttle, it will turn at 4 mph (no load speed) and continue "growling". It does this in any throttle position. The growling noise and vibration goes away the instant I release the throttle.
The intermittent is not "normal". Sometimes I can ride 10 miles with no problem, then the next 10 miles (e.g. on return) it will have the problem. It coincidentally likes to leave me as far from home as possible! Occasionally it will alternate between working and not working, but it usually either just works or doesn't.
The battery voltage is good (~48V), it pulls >5 amps for the 1 second when I blip the throttle and get thrust, then drops to less than 1/2 amp.
I've checked wires, switches and connectors including the hall sensor wires and don't see anything obvious.
I'm suspecting the controller or possibly an issue with the hall sensors but really can't think why either would cause this problem.
My wife's ebike is a 9C with 20A controller. I'd do a controller swap, but the motor connectors are different and there is no hall sensor wire on her controller. I know the 5303 didn't operate when I disconnected the hall sensor wires, but assume that may just be that the controller won't operate without hall sensor input.
Any suggestions are appreciated.
Chris
Chris
