TSDZ16 Had Stability issues -- Resolved: Torque Sensor was replaced
OutbackIdaho
🔌 New-ish
Payette, Idaho
Greetings from Idaho
Had a Bafang M625 for 5 years but batteries became extinct. Decided I had enough of ghost pedaling. Swapped the Greenspeed Magnum XL over to a TSDZ16 motor. Have been working on this all through my staycation to not much avail. Cannot get past 10 MPH no matter the speed setting on a EKD01 display.
Note: Am quite aware of the torque differences on the Nuvinci (60 nm) and TSDZ16 (160 nm).
Came here because this forum is quite famous, and a lot of experienced individuals reside here. :)
Bought my TSDZ16 from Johnny Nerd Out along with two 48V 17.5Ah batteries. Have no issues getting to 10 MPH, and the speed was increased to 35 MPH, although had a higher setting with no change. I don't plan on going over 28 MPH if I can help it, cant wheels are scary at that speed.
What I have tried or done"
  • It's not in Street Mode, is currently at its maximum near maximum speed of 35 MPH.
  • Have it set to 20" wheel size, even tried 21" as I have 20 x 2.15 Schwalbe Pick-Up Cargo E-bike tires. 1640 circumference.
  • Have tried moving the speed sensor from 3/4" to up close and personal, no change. Have a Bosch magnet to install that just came in.
  • Mode 5 gives an easier pedal, yet no speed increase past 10 MPH. Feels like the display/motor is not unlocking, and I'm ghost pedaling at 10 MPH...
  • Does not matter what mode I am in, there is no sustain in power nor any speed increase. When my personal speed lowers the power kicks back in at 5 MPH.
  • Have spun the snot out of the pedals and no change. Think I do 50 to 60 RPM on my own. Plodding along or fast pedaling makes zero difference to output.
  • Throttle really gets with the program and it zooms up with maybe half a turn of the chainring. Boom! Stops at 16 MPH. Again, feels like something is not unlocked.
  • Have satisfactory get up and go from pedaling anyhow as was used to that on the M625.
  • Have tried various gear ratios on the n380. The hub is still functioning.
  • Put on the 42T chainring when I was assembling the motor. Do have a stock 44T chainring, but the 42T is more sleek.
  • Speed sensor is on the back wheel. Used a nylon bracket with a speed sensor mount to offer better angles to spoke/magnet.
  • EKD01 has SW: EKD01_TB_N22 & HW: B02NU_V1.01
  • Anderson connectors... plan on swapping to XT60's once I can get this thing to get to 16 MPH on its own. (Warranty thing)
  • Factory Reset on EKD01 did no good, tried a few times in fact.
  • When I had the Bluetooth app connected, it did not show any updates. Bluetooth is disabled when I am riding, don't trust it. Heard rumors it can set the motor to Firmware settings, overriding the display.
    Can get between 6 to 10 MPH, then no increase no matter what mode I select. I'm perplexed. Bench mode I can hand pedal it to 10 MPH with effort, and bench test works. Actual road test however...
YouTube bench test - Appologize for the breathing, long days - not enough sleep trying to figure this thing out.
YouTube road test, Garmin recorded the on screen displays, camera recorded the EDK01 display & cadence of my plodding. Was tired. Am tired.
Thus I am totally perlexed as how to proceed. Should I install the OEM rear wheel with cogs for a test? About the only thing I can come up with.
Did notice an oddity last trip out. Was going along and the motor was spurting, then died. Had no power. Went and road manually, and got a safe place to look at the battery did not fully lock into the tray or something, and it slid out. The trap kept a grip on the battery just fine.
Connected the battery, and started riding back pulling a Wike trailer with maybe 50 pounds of load over the axle. The power sputtered, and the trike moved like the trailer hitch was undone or on a rope, but that was not the case. Got home, removed the trailer, and went for a normal ride.
Motor still sputtered or surged erratically. Thought what now?!? Not sure if the Anderson connectors got hit by a strap water spurt or puddle, or if the trailer causes too much drag, or what. Stopped, checked the wiring, reconnected a few times. Seemed to lessen up. Hit the throttle a few times, no issues. Was about to send a note off to the vendor.
Decided to turn the motor off. Disconnected the battery. Drained the display's power. Did a factor reset (which I only think it resets the display, not the motor). Turned the battery power on and off a few times. Then went for a ride and it was functioning normally again.
When the weather cools down some I'm going to get some XT60's and replace those dumb Anderson connectors. Are there some really good XT60 connectors, or are they all about the same? Want to be able to get a good water resistant seal from the connector to wire areas.
XT90s appear to all be manufactured with anti-arc resistors incorporated. If you're going to change the connectors anyway...
Was trying to locate a 50T chainring for the TSDZ16, just not found anything past the 48T that really takes a lot of humping to get to 20 MPH. Would like to attain 20 MPH without a lot of strenuous effort.
Not looking to be a speed demon. It is mostly the flats is where this motor lacks oomph. Unless there is some sort of grade it falls short on support when riding laid back.
I use this 75t ring on my rear hub ebike:
No idea if you could get an adapter to fit it on a mid-drive, though. Also annoying it isn't narrow-wide tooth sizing to help retain the chain.
Looks like I would need some sort of Spider Adapter that allows one to add a 50T outer chainring to the adapter. Interesting concept. Now of one could find a 44T chainring to fit this adapter, a person could carry the spare in case their terrain changed.
For instance, Trail of the Coeur d'Alenes, while mostly flat or with a slight grade, there is an uphill grade past the Chatcolet Bridge up a few miles that goes up to 5.4% grade. With a smaller chainring to swap over to, that could keep the TSDZ16 from overheating. Not saying that this would happen a lot, we all run into hiller areas that a 50T+ could be an issue.
The grade coming down from Plummer to the Chatcolet Bridge was what worried me in the 5%ish area coming on drum brakes. I'm not a fan of drum brakes. The conversion kit is roughly $1,000 AU to obtain from Trisled, and WhizWheels has yet to give me a more localized proce. Me, rather have Avid BB7's onboard. Could swap them over from the Rover, but that whole conversion is another topic, and I think I've gone astray on the original topic here too...
In any case, I got past the 10 MPH issue by adding a larger chainring.
While the online AI's suggest 44T on recumbent trikes, that suggestion is flawed and not correct. Maybe on diamond frame bikes, not on those of us who are laid back. 44T is nice to pedal with, but speed is not on your side. 46T I can get better speed using, although you have to be quite active in pedaling. When a person gets tired though, and plods along on the pedals, speed is going to drop.
Was suggested a 50T to 52T chainring would allow a more comfortable pedaling experience on the flats or rolling roads. Should the suggestions be true, a 50T chainring could allow one to pedal at a more comfortable pace on rolling or flat roads without spinning out the RPMs on the motor sensor. Taking on hills could be a challenge as the motor would have to work harder, and I have no inclination in abusing the motor (want it to last many years).
If I am going to spend a lot on a spider adapter I would like it crafted of superior materials and would also like a color option instead of basic black. Trike's trim is yellow, although purple or orange would let it stand out. :cool:
Small wheels have a much more pronounced effect than lounging body position. In terms of road speed per pedal rpm: 44t on a 26" drive wheel is like 39½t on 29", 48t on 24", or 57t on 20". 72t on 16".
Recumbent and folding bikes that use child sized wheels have special gearing challenges as a result.
The NuVinci hub has less overall gear range (380%) then a typical derailleur system (often 400% or more).
The Rohloff hub has a 500% gear range.
Gear range loss will limit the top speed.
One revolution of a 20" wheel will move the trike roughly 63" down the road. (5 feet)
One revolution of a 26" wheel will move the trike roughly 82" down the road. (7 feet)
Small wheels need transmissions with larger gear ranges.
The small cog on the NuVinci is compatible with Shimano 9 spline cogs so you may be able to get a simple, inexpensive ratio change with a smaller cog. It won't be much change.
When TSDZ16 meets chipped gravel, avoid it like the plague! Don't go past Mode 3, and should things not work correctly stop and perform a Factory Reset and reset everything from scratch. Gets highly annoying! The programmers for these motors need to do some work here, this is not working well.
Due to language I used, set age restriction to 18+.
Vendor wanted me to disconnect anything that could cut the motor off. So disconnected both brake sensors and the shift sensor before heading out this morning.
Started off... had no assist anywhere, no matter what mode I was in. Did a factory reset within the first 5 minutes. Tried again, thought I felt a brief moment of assist, but was gone. Was a bit miffed at this point thinking I had a dead motor.
Decided to record a few videos of this new issue. None picked up the motor's whine. Did another factory reset under a mile away. Waited a bit, then started off. No assist then either, no matter what I tried. -- Only the throttle worked. Motor was dead as far as I could tell.
Rode a bit plodding along at 7.7 MPH (46T chainring). Remembered the vendor asking me if the display turned off when the assist power surged, and told him the display never turned off and the speed was the same as the Garmin's. And no error code was thrown. Speed today was right on, only thing different was no shift sensor connected and both brake sensors were also disconnected.
Since I had no 'proof' to show the vendor that the display/speedometer were functioning, decided to take a photo with the iPhone. Went over a couple of bumps and some gravel due to traffic. Was lining up the two speedometers in the frame ... and out of the blue the assist kicked in! Seriously?!?
At this point I had to make a decision, to ride and possible have a very long unassisted ride home, or stay locally. Decided to chance it and find this chipped gravel to see if things went awry again.
Got out to the roads that had chipped gravel on them last weekend... and these roads were covered in fresh asphalt. Sort of ruined the testing idea with the disconnected peripherals. So went to the usual area and found the ranch was covered with people and cars. Took a while before I could even cross the highway cause there was so much traffic. And man o' man, there was a HUGE Spartan Challenge race going on today & tomorrow. Got some static and 360° photos to go through.
Did ride 28.56 miles without any motor issues. However the battery sure drained faster than normal. Not sure if that was a fluke, or if something is up somewhere.
And what would cause no power assist at all for 1.7 miles?!? Then suddenly kicked back in and functioned normally??? Want some reliability out of this TSDZ16. Never know what is going to happen next.
And I have to figure out why the chain pops. That shift sensor was quite a charm. Will have to check the rear derailleur tomorrow.
Here are three videos pieced together to show the start of the day, and when assist kicked in. Did not have any further issues that were noticeable. However, the motor sounds lighter/tinnier, or is it just me?
The vendor I bought the TSDZ16 from first said he wanted the motor back to diagnose the torque sensor. Said he would pay the shipping. Due to mine not having power for 2 miles before it kicked back in.
Subsequently I rode three other times and the motor is still providing assist. although it feels (to me) like it is holding back.
Now the vendor (Johnny Nerd Out) is blaming me for not putting enough pressure or RPMs on the pedals, and wants detailed analysis. Seems a bit over the top there.
Had looked up the idea of Power and RPMs when I was recommended by Google AI to a V3 Analysis device that was discontinued.
So how does one 'affordably' record their RPMs and Power used on the TSDZ16, or is that even possible?
The EKD01_TS does not show the information, and cannot even get the other 4 PAS levels.
Of the 9 PSA levels, 1 through 3 are made more for 2 wheeled cyclists. Modes 4 through 9 have more lenient input for better output geared more for recumbent trikes. So on a 5 mode PAS display, 3 can be iffy at times. 4 is better, yet I long for a mode between 4 and 5, as 5 is overkill on flat roads, and is awesome on hills and 'up' grades.
Vendor thinks I am not putting enough power into the motor. which he forgets all the stuff I've gone through to even get to 15 to 18 MPH on normal pedaling, and up to 22 on extreme pedaling. Sorry, I'm no athlete, so extreme pedaling is only good for sport. Did get to 22.3 MPH, and it took a lot out of me to get that far on a slightly sloping road about a mile long.
Do not know of any affordable device that can measure one's input RPM and Power.
Vendor thinks I should go back to cadence since he thinks I cannot pedal fast or hard enough for the motor, then the software is the real limiting factor.
Had no issues when recovering from covid pneumonia that wiped out my body on a TSDZ2. It's just the TSDZ2 was not made for a guy like me, and the top vendor back 6 years ago said I needed at least a 1,000 watt motor.
Ended up with a Bafang M625 that worked great on two different trikes, till Bafang ended its life and could not buy batteries for the motor without replacing the controller inside the motor -- which required lots of fitting changes.
Thusly, will have to ride with what I got and learn to be happy with it until it goes bonkers or 'plays dead' again, then see if the vendor will honor the warranty. Or should I contact Varstrom directly?
And the only way to get a 50T chainring is to get a spider adapter and outer chainrings to get there. So going to stick with 46T.
This motor is cursed.
Started out yesterday, no assist. Factory reset twice, nothing. Moved speed sensor closer to the magnet and it came back to life. Before it would read erratically for being too close. /shrug
Get out into the urban farmlands and an unexpected storm system was coming through. So I ended my journey, and started heading back. Got a ways, sounded like the chain popped off a rear derailleur (on my end of the recumbent trike), and assist croaked shortly after.
Suffice it to say I moved speed sensor, no change. Factory reset did nothing. Throttled back some miles, periodically checking to see if assist would come back, and within about 10 minutes of the motor croaking it came back and had assist again. Luckily only got a light dusting from the first two storm cells. Got home right when the third storm cell hit, and the sun was setting. Threw a sun tarp over the trike to keep it dry why I sat in the car donating blood to the mozzies that got inside with me.
Should of stayed with cadence, despite me thinking torque assist would help me rebuild strength in my legs and knees -- which I think it has been helping. Not has so many dramatic issues with a motor before.
And it's Bafang's fault for killing off the M625 & not allowing third party battery support. I mean, if they was killing off the motor, why not unlock it to be used with other batteries?
Now to see if the vendor (Johnny Nerd Out) will allow the motor to get sent back to him or what. Should of went with a BBS02. I know the M625 was bomb-proof. Never once had an issue with the motor other than ghost pedaling was meh. Wanted more exercise and longer rides.
Why does the TSDZ16 have so many issues? Why can it not just work all the time?!?
Short video: https://www.youtube.com/watch?v=5S_cAAY2Li4
Original 12 minute version: https://www.youtube.com/watch?v=wQUb-pbE-hI
Maybe you got a lemon? Other folks seem to be doing ok with this motor?
Initially it was a speed issue. Once upgrading the chainring to 46T was when the assist issues came into the scene.
Am guessing the larger chainring brought out what was lurking from within? /shrug
Thought swapping from Cadence to Torque was only going to be transition in pedaling.
Figured I would give #Tongsheng another try. Had a TSDZ2 but it was too small a motor for my weight back in those days.
Then a friend found a deal on the M625 and had many years of fun ... yet I am not a fan of ghost pedaling.
Thought TSDZ motors would have to gotten better.
Is the TSDZ8 more reliable, or just as buggy??
Back in my beta testing years I had this motto: If there is a bug it will find me.
the speed issue looks to be entirely the fault of the small wheel on recumbents and trikes.
having had the tsdz8 before the tsdz16 it is very noticable that the tsdz16 is already geared to a lot lower rpm than the tsdz8 which is geared like most mid drives.
the tsdz8 with a 38t chainring and 19t in the back on 27,5 inch tires i got to 34 kph with the throttle.
with the tsdz16 and the stock 46t chainring with the 19t in the back on the same tires i got 30 kph exact with the throttle.
looking at the manufacturer specifications they say the tsdz8 has a 1:37 gear ratio and the tsdz16 a 1:22
but from my testing the z8 reaches close to 5000 motor rpm and the z16 only just above 2000 motor rpm.
Vendor wants to check the motor out. Have to taken the motor off today, get it packaged up and weighed. Was going to do that yesterday but wanted to take the motor for one last spin as it would probably be a while before I seen it again.
Took three factory resets to get any assist starting out. Rode the to New Plymouth, cruised around slower playing Pokemon Go - it's something fun to do and gives incentive to ride. 15 MPH cross winds.
Was headed back and decided to take a small detour to Bluff Road's "there this hill" run. 3% grade on one side, and 3% to 5% then tapers on the other side. It's a short thrill area.
Went up the long ascent well, no issues. Went over the hill and braked a bit as there is often scattered rocks across the road. Besides, 25 MPH on a Greenspeed Magnum XL is plenty fast.
Turned around and went up the steeper run. TSDZ16 did fine. First time I went up this grade was in 5th gear Mode 5. (Mode 5 is the hill climber!) This time I started out in 5th but went to 6th gear and did 16 MPH up the 5% side, then kicked it to higher gears and came out doing 18 MPH over the top. Coasted most the way to the main road and was headed home. Had some fun for a change, no rain storms cruising through.
Got to the one area where I relax a bit more. was putting on more miles this trip, ending at 38.45 miles. Swear there has to be something in this one area that is off (supernatural, geomagnetic, something). As was riding through the area in Mode 4, 7th gear, and just climbed into 8th when I started slowing down. Don't think I had the camera recording beforehand... lost all assist.
Rode back with some pedaling and mostly throttle, with display set at 20 MPH max to keep the wattage down. Did like nine factory resets the entire trip. Speed sensor had a 0.2 miles difference than the GPS, so it was working. Did the speed sensor adjustments as last resort: further in, no change; further out, was losing 0.4 MPH so moved it back to roughly 8 mm. No other sensors were connected.
Most of the ride back was 11 miles, battery dropping due to using the throttle. (Had phenomenal mileage prior to this.) Did not bring the other battery as had not planned on riding as far as I did. I base the length of my rides by how well the battery was doing, and it was acting like it was when I first got the DZ16, barely used any battery.
Was checking for assist every so often and at one point I had assist for one complete crank turn, then nothing. Was pedaling when I could, coasted, and took it easy on the way home. 12 to 15 MPH on throttle, it maxed out at 20 MPH on this lower setting.
On video playbacks I noticed the motor sounded more higher pitched, but I did not run the footage through the Insta360 Studio either, was the raw MP4 sound.
Got home and my left thigh muscle spasmed and made getting out of the trike more challenging. Assist bar and a fence got me up and out. Whew!
Motor got sent back to vendor as it died again.
Had rode 36 miles, and the last 11 by throttle and pedaling as assist went out and did not come back. Think I heard the assist/motor kick on once while reviewing video footage - however it did not even last one full crank rotation before it was dead again.
Now to install a crankset and figure out how to install the front derailleur. Never used the front derailleur as we had immediately swapped over to a Bafang M625 from the previous TerraTrike Rover. May have been better sticking to Cadence assist after all this experience I've had with the TSDZ16.
When the DZ16 works it flies up hills and inclines well. On the flats is soft of sucks without a large chainring.
Is Jonny repairing it?
Am going to assume yes. The motor got sent back on Friday.
Pedaling this GS Magnum XL without assist really puts the organic engine in the slow lane. Got a bit over 9 miles in 2 hours. It's going to be a long wait I bet. Flies and mozzies were going faster than me. :\
JNO said they would mount the setup on a bike and test it out, and replace anything that is needed. Doubtful they will have a recumbent trike to try these motors out on. Still, it was dead for 11 miles.
JNO's Technician replaced the Torque Sensor. Motor was under a 6 month warranty. Had it maybe three months. Normal charge for the replacement part around $100, probably the same for labor.
Others claim this was an easy fix, and to put silicone grease on the PTFE tape. Will have to look this up for future reference as I've yet to crack open a TSDZ16. Might have to in the future without a warranty.
Do these torque sensors go bad often?
Glad it got fixed! Wonder how you'll like a functioning tsdz16!
Motor arrived today. May not get it installed until Saturday though, weather.
Turned the gear a bit by hand and it feels and sounds MUCH different than the original.
When I first got the motor it sort of felt soft, taking a few turns to move the spindle.
Now it is quite strong to turn and the spindle moves as the gear does. Spinning it backwards can hear pawls clicking. That wasn't heard when it was new. If I did not have to work tomorrow could put the canopy back up and see how this fairs. 😲
Save
Got the TSDZ16 installed yesterday. Did a 13 mile ride and it performed well. Performed like it was supposed to, with support at mode 1. Still no way of getting 9 PAS levels though, only 5.
Altered the mounting brackets that upright cycles use. Not sure if I posted those before, inverting them against one another. Wanted a slimmer spacer, and used an older type of chain tensioner with has a smaller bolt. The bolt could give a place to add a different type of light source, an under-carriage camera, or one of those guardian/MTB bells.
Use a screw through a front bracket to take up slack.
The vendor's technician forgot to put the plastic mud/wire guard back on the motor. Contacted said vendor and he is to send one back. I opted to purchase a steel 46T chainring as not sure how long the aluminum one I got from AliExpress would hold under higher weight, so bought one and that way JNO won't have to pay for shipping the item back, and I can replaced the chainring with the now in-stock OEM version.
