irony_delerium
🧲 New user
So, I've got a TSDZ2b motor installed on my electric trike. Worked fine Wednesday.
Today, took it in to the shop to have them try helping me with a bit of hardware (I've got a bearing that needs replacement), and so I took out the batteries and brought it in; when I got it home, I put the batteries back in and powered it on.
It's running OSF, with a VLCD5 display (yep, stock display, haven't changed it yet), and it's set to display the current battery voltage at power on - usually, it'll power up, briefly show "53.0" or "54.2" (maybe "55.4" or the like if I've just pulled it off the charger - LFP, not NMC), show a semi-accurate battery meter, then drop to zero. At present, it's powering on - the display turns on, the other hardware on the bike (the lights and dashcam unit) power up off of the 12V buck converter attached to the battery, which all suggests to me that the battery is fine, maybe needing a charge, but the controller seems to be doing nothing: it's not reporting rotation counts to the display - speedometer reports 0 constantly, it's not accepting inputs from the throttle or pedals, and it's basically behaving like a lump.
Any troubleshooting steps? I can always reflash it, both to another build of OSF and back to stock, assuming the controller isn't toasted. (If it is, I've ordered another.)
