TSDZ2B intermittent assist cut-out
ebike_builder
New here
Boulder CO
Hi -- I have built my wife an e-mtb using the TSDZ2b mid-drive motor with 860c display and OSF software. It has developed a problem where the assist randomly cuts out (display stays on). Initially I thought it might be related to overheating since we have had very hot weather here. When the assist cuts out, powering off/on the display will bring the assist back. This used to happen only infrequently, but today (temps in the low 70s) it must have happened 15-20 times in an hour ride. Very frustrating. Note that there is no temperature sensor so although it kind of behaves like thermal throttling, that shouldn't occur w/o temp sensor. The only thing different about today's ride was that the battery only was charged to 40% to start the ride and gradually decreased to 30% by the end. It did seem as though the lower the remaining charge, the more frequent the assist cut-out. I felt the motor and it was just barely warm to the touch.
The battery is a Hailong 52v 13ah
Looking for troubleshooting ideas and possible causes of this behavior.
Thanks in advance,
--peter
Before you go into the weeds ...
Check that the speed sensor has not rotated away from the magnet mounted on the spokes. It's been my experience that when this happens the assist will disappear, then reappear, then disappear, then reappear ... and on and on. Just rotating the pickup back into alignment with the magnet resolves the issue.
@cultRider -- thank you so much for your simple suggestion! I just checked the speed sensor and found it noticeably misaligned by 40-50mm. Without your idea, I would have never thought to check that. Charging the battery now and will go for a long test ride. Will report back after.
Experiment with different alignment between magnet and sensor. Too close is not good. I've found a slight offset (as in pic) gives a better signal.
I am happy to report that realigning the speed sensor fixed the motor cut-out issue. Thanks again to @cultRider. BTW I aligned the magnet with the arrow (no offset needed).
Further update: my wife went on a 15mi ride and found the occasionally the power still went out (nowhere nearly as much as before though). She discovered that using the throttle would always work and then powering off/on would restore normal PAS. So at this point I am thinking there may be an intermittent problem with the torque sensor. I'm pretty sure that the throttle does not need the torque sensor to work.
Wondering what could make the torque sensor stop working, but always start back up after a power off/on. Any ideas? I suppose I could test by trying the magnet alignment suggested by @Zambam.
The speed sensor on my TSDZ2 was not happy if the gap between it and the magnet was closer than 15 mm or so. Try experimenting with that also. Other things to check is the battery setup menu. Is everything set properly?
I checked the gap for the magnet -- it was approximately 10.2mm. Interestingly enough Tongsheng recommends making this gap 10mm.
I have the 860c display with OSF version V20.1C.4-2 installed. There is no "Battery Setup" menu, but instead here is the "Battery" settings page. My battery is a 52v 13ah Hailong
Note: I checked the speed sensor connection and noticed a very slim amount of yellow showing. After reseating it, there is no longer any yellow visible.
Headed out for another test ride. I will leave the 10.2mm gap to the magnet for now. BTW I have purchased a set of pedal extenders, but will only use the lefthand one to hopefully further prevent accidentally kicking the left chainstay with my heel. Picture attached also.
Update: pedal extender was a big improvement in left side Q-factor. Test ride had a 1000ft climb (avg 7% grade). Made it to the top of the climb (only in assist level 1) with no drop-outs. Then turned off assist for ride down. About 1/2mi after turning assist back on, assist cut out. Checked speed sensor alignment -- fine. Powered off/on and assist was back for the remainder of the ride.
At this point I am starting to wonder if it is possible for a speed sensor to be faulty. Seems unlikely since it is such a simple device. Another thought: somehow (bumpy road perhaps) the rear wheel momentarily moves closer than the the 10mm spacing to the speed sensor. So I am thinking of increasing the gap (by rotating the speed sensor) to make it a few mm larger.
Does anyone think it is possible that something as simple as a speed sensor could be faulty?
Do you think I should raise it? If so, that seems counter-intuitive since the cut-off always occurs at very modest power levels.
Follow what your manual recommends. If it only happens at modest power levels, and your motor never feels hot to the touch, maybe it could be intermittent electrical continuity issues in the connectors or wiring. Do you have any sharp bends in the wire harness routing (like 180 deg bends)? I'd undo them, test ride and see if it helps.
edit: Does the sticker on your motor state that it is rated for 52 V?
I just swapped out the speed sensor for a new one. Will test that before anything else. Note the 52v is the battery rating not the motor. The TSDZ2 is rated at 48v. I doubt that's an issue since the problem only recently started occurring.
New speed sensor: no change had two assist cut-outs. At this point I think we need to just live with it ... sigh.
Here's a thread TSDZ2B OSF - Random Thermal Throttling of someone with the same motor and display as your's but not exactly the same issues. I don't think you should just live with it. Try to fix it!
I had read that thread, but assumed that without a thermal sensor installed, the controller (with OSF) could not cut out assist. I notice that if I set one of the display areas to show motor temp, it always reads 31. In the "Motor Temperature" section of the settings Feature is set to "Throttle" which should disable any temperature throttling. Just in case that is not the case I have raised both the "Min Limit" and "Max Limit". I would be truly surprised if this makes any difference.
Any solution for this issue? I have a similar problem.
My TSDZ2B with OSF is working flawlessly with full batttery, but cuts off (not even the throttle is working) at arround 45V. Restarting the screen reenables the assist. Cutoff voltage is set to 40V. I have a power meter inline and the voltage doesn't go under 43.5V even under 10-12A load.
I rewrote the stock firmware and motor works fine at the same voltage 43-44V
Look at post 3474 by testi on page 139 of the big OSF thread. He had a similar problem. and it's discussed there.
Yuu can lower the cutoff voltage to 30V and that is a work around, or load the latest OSF versiom where mbrusa said he fixed it.
Yes, it seems some other guy had the exact problem and mbrusa fixed it with update 6. I had update 5.
Thanks for pointing me in the right direction.
