first.loser
I have a TSDZ2B with OSF.
When it is behaving normally, the temperature would be something like 20*C up to 38*C.
However, I have instances when the temperature would shoot up from 20*C up to 60, 80, 120+ *C even while I am fully stopped at an intersection.
I have tuned the motor down to draw a maximum of 8amps from 11 amps thinking it is drawing too much and heat builds up.
I have also turned down my assist in power and torque to provide 10% more in level 1 up to 20% more in level 3. (I only use level 1 assist most of the time).
Initially this seemed to help since my temperature no longer shoots up. It was like this for almost a month. However, yesterday it started to temperature throttle like crazy at 120+*C.. even at level 1 assist. I also noticed progressively weaker assist halfway into my commute even thought it says I am getting an additional 70 watts of electric assist.
I am trying to figure out what is going on here. According to my 860C display I normally draw 2.6amps and never went over 7.9amps..
Could a battery cause this?
Here are my specs:
TSDZ2B with OSF and 860C display 48v 750W
Brass Gear
Premium cooling Kit from ebike stuff (plate, fins, everything)
Temperature Sensor (LM35 bought from digikey)
Battery is a RADMISSION 1 48v 10.5aH 504wH which I got from my old bike. I've only been using the supplied charger for it.
I limited the TSDZ2B to provide no more than 300 watts of electric assist. I really under powered everything to try and eliminate the heat problem.
Here are my specs:
Brass Gear
