View attachment 379187View attachment 379188i got the Chinese segger here but all jlink v9+ have theuart to comm ports. Easy way to understand is All the pins on the left have 2 functions each and all on the right are just grnd except a few on the top. The other pic is my bodge £8 usb2uart flashercurrently I got my 860c display plug disconnected because I was playing around with my sab controller the other night. But basically the way you're looking at it, bottom pin is ground then rx tx (either this order or swapped can't remember) in the middle then the 5v top. 5v and ground to to the buck converter at the top to the "in" side + and - then the"out" side + goes to display 5v and - to display ground. You need a buck converter and set voltage to at least 30 or display won't work.
1 solution that MAY work for you if u have UART on your segger, you can try power display from your bike that way you can skip the whole buck thing. Don't connect it directly to battery though, you'll need to plug it into controller ports power and splice tx +Rx to your segger I think (if someone can confirm)
Also if I wanna try this way , while u do it get a usb2uart and buck for next time and/or if it fails flash. Mine would refuse to boot to home OR power up alltogether when it failed luckily I could still flash it back to working
I promise this is the very last question. Thanks to your detailed explanations, I now have a perfect understanding of what to do. Thank you so much!
I searched for USB to UART adapters on AliExpress and found so many similar products that I'm worried I might buy the wrong one.
If it's not too much trouble, could you possibly share the name or a link to the specific product you used or would recommend? I would feel most confident buying the exact one you suggest.
I'm sorry to keep asking questions, and I sincerely appreciate all the help you've given me. Thank you again!
