I’m reading this forum frequently for quite a while. Now it is time to make my first post and
introducing myself and my ebike
Just to share some information about my ebike build instead of just reading
Parts:
- Turnigy 80-100b 130KV (bought it from some students, they tried to use it for their solarboat http://solarteamwindesheim.nl)
- An old computer PSU, changed it for the battery charger.
Hobbyking:
- 1x TURNIGY MEGA 380W Lithium Polymer Battery Charger
- 6x Turnigy 5000mAh 5S 20C Lipo Pack à 63V 10Ah
- 1x H-King Cellmeter-6 Lipo/Life/Li-ion Cell Checker & Alarm
- HXT 4mm Gold Connector
- Turnigy Pure-Silicone Wire 10AWG
- JST-XH 5S Wire Extension 20cm
sdp-si.com:
- A 6C 7-25B72 - 0.25 (#25) Pitch, 72 Teeth, 0.5" Bore, Metal roller chain sprocket
- A 6Q 7-H25 - 0.250" Pitch heavy duty hardened steel roller chain
- A 6X 7-2514 - 0.25 (#25) Pitch, 14 Teeth, 0.25" Bore, Metal roller chain sprocket
- A 6Q 7-H25SCCL - Spring Clip pitch, Hardened Steel Roller Chain Type Connecting Link
- S40PX0-CHS4-011 - 0.5" Dia., 5.50" Length, 420 Stainless Steel, Shaft Case Hardened (Rc 52-56)
EPBuddy:
- ParaBoard-XH with 4mm Bullet Connectors 40A Version
Ebiks.ca:
- Cycle Analyst
Eclipsebikes.com:
- 3 Chainwheel 48T (freewheel), 48T, 32T
- Cranks
- Chainguide
Forum members:
- 12 FET controller (Lyen)
- Throttle (Lyen)
- 0,5" freewheel adapter (Matt)
- Hall sensor mount 120deg. (Gwhy!)
Other:
- Some aluminium for the frame (aluminiumshop.nl)
- Freewheel (local bike store)
- Ball bearings (ebay)
The overall reduction is:
- 1st stage: 14 - 72
- 2nd stage: 16 - 48
- 3rd stage: 32 - 20(?)
So the ratio will be around 1:9,6 - no idea if this is a good ratio it will be a little bit try and error :wink:
All the feedback are welcome!!
Picture timeline: (lost a lot of pictures because of a migration to my new mobile)
a couple of the parts from sdp-si!!
drilled out the little sprocket to 12mm for the motor shaft and add some "security" bolts
the aluminium plate (and some of my other junk)
building the mount, it wasn't right-angled so adjusted it a little bit
getting nervous
the bike and adding all the stuff together
removing the crank ain't got the tool for it
This week i will post some more photo's but for now i reached the max number of pictures
Parts:
Hobbyking:
sdp-si.com:
EPBuddy:
Ebiks.ca:
- Cycle Analyst
Eclipsebikes.com:
- Cranks
- Chainguide
Forum members:
- Throttle (Lyen)
Other:
getting nervous
