Rikobonito
Crazy ! WAAAANNNT !!!
Enjoy
this works, but a trimmer pot works even better, so you can ensure you do get full WOT when requested.cam777 said:"I have noticed that 100% of the power is applied at about 50% of the available thumb throttle travel. I would like to know how to make the physical movement of the throttle equal a 1:1 application of power?"
For my electric longboard transmitter I had the same problem. The solution to solder a 10k ohm resistor in parallel with the potentiometer to get the desired throttle range.
MrDude_1 said:this works, but a trimmer pot works even better, so you can ensure you do get full WOT when requested.cam777 said:"I have noticed that 100% of the power is applied at about 50% of the available thumb throttle travel. I would like to know how to make the physical movement of the throttle equal a 1:1 application of power?"
MrDude_1 said:while the work you have done looks amazing... I think you are going to be disappointed in the scooter.
It will not be so quick that its scary.. it will actually be slower than a goped with the torkinator aftermarket motor.
It will move, but it will accelerate like an electric skateboard. Fun, but not scary fast. if thats your goal than its an excellent job... but if you want it to be scary quick like you claimed... you're going to need more power... like a 80mm motor, and an ebike controller.
1th I was looking to make my frame myself like you, but ... I have no knowledge and practice in this field so looking to customise a Razor (or similar dirt "push" scooter in 6,8 or 9" wheels if possible)beetbocks said:your scoot looks very similar in design to the Goped Knowped (same wheels - i know) ..which looks a nice simple yet strong construction .. looks very rugged!
for £279 - you can get a version with 2x brakes ..
And yes this will be a perfect compromise, half way between the full DIY and the customization of scooter in e-scooter. Thanks for the link Beetbocks :wink:beetbocks said:maybe perfect for a conversion ?
http://www.ebay.co.uk/itm/GOPED-ADU...148289?hash=item3f6f3c1581:g:0SUAAOxyEoFSU8Nl
