AussieJester
1 TW
G'day Gents...I spent yesterday cleaning my workshop, it is all nice and clean and organised once again
and best of all fiberglass dust FREE..I also cut up my remaining curb side bikes (8 in total)
kept the small bottom brackets and head tubes for new projects some of the larger tubes a few rims and hubs
and the rest is piled ready for scrap metal merchant to collect.
I have some pictures from last week of the battery enclosure mounting along with a left hand freewheel adapter
i knocked up this morning-->
Update
The original battery enclosure mounting brackets i made were too narrow, so were scrapped in
favour of new wider mounts. I have incorporated some 10mm aluminium into the mount
setup also, heres the pics i took of the procedure-->
I will actually be making a small alteration, the middle two sets of cap screws are the ones that hold the
enclosure to the ali mounts, these will be scrapped, two fresh holes will be drilled (narrower again) and tapped with 8mm tap
what i SHOULD of done in the first place, the moment i had finished whacking the 8mm drill bit
through these i realised i had frocked up. None the less, not a major issue to rectify, shall re-drill and tap them
slap a lil resin and glass inside the enclosure to block the current holes and redo them WHY?, makes it a shit load easier
to remove the batter enclosure, 4 bolts instead of 8 and no nuts used to fasten the enclosure to frame mounts.
OK..on to the manual pedal drive train, i usually don't do any work on weekends
but i was inspired by a nice clean workshop so i tackled the left hand thread
freewheel adapter for the southpaw freewheel this afternoon...
I have used a bottom bracket bearing cup for the adapter along with a disk brake
mount i fabbed up for the trike hub (in pic) using a front dual disk brake hub
from Choppers US. You could make a round plate and drill the disk brake mount
holes from scratch but i had this already and it wont see use again so it was "re-purposed"
As can be seen in the final pic the clearance is minimal, it actually wont be as bad as
pictured, the bolts used to hold the disk and adapter to the 3 speed hub are button head cap
screws, they protrude up a good 8mm I will swap these out and replace them with counter sunk
cap screws gaining another 4-5mm clearance. I new it would be tight fit, i thought it would go though
and it does so i am please about that.
I'll make the minor adjustments to the battery enclosure mounting tomorrow, i also need to
re-think or rather redo the lid arrangement, the hinge i have installed now is not going to cut it. The
battery enclosure being raised doesn't allow as much room to access the enclosure as i thought it would
SO, i will glass up the recess for the hinge along with the mounting holes, glass in some aluminium plate
that ill drill and tap holes in for some thumb screws too screw into, the lid will then
be fully removable for easy access to batteries and electronics.
Thats it for this afternoon fellas...ill be back tomorrow ...hopefully, with some more to report
i reeeeally must bite the bullet and notch the chain stays tomorrow also, has to be done :: sigh ::
KiM
Update
KiM
