HumboldtRc
- Joined
- Aug 22, 2010
- Messages
- 267
Looks like a nice little stainless box.
http://www.hobbyking.com/hobbyking/store/__24647__Turnigy_Lipo_Bunker_Lipoly_Saftey_Charge_Box.html
There are only two times a battery can fail, during charge or discharge, and while you can not control what happens in your model you can control what happens during charging with the Turnigy Lipo Bunker.
Constructed from S304 certified stainless steel to withstand temperatures in excess of 800 degrees Celsius, the Turnigy lipo Bunker is a bullet proof safety enclosure designed to contain flames and help minimize damage to surrounding objects in the event of a lipoly failure. The duct will ensure heat, flames and gases being expelled from a lipoly battery will be vented in a direct and controlled manner.
Specs.
Case Material: S304 Certified Stanliess Steel
Dimensions: 180mm x 90mm x 90mm
Specs.
