RichiePA
Hey all,
It’s been a little while since my last post I’ve been really busy the past few months with uni and karting so I haven’t lavished as much time on the bike as I would have liked to but thats all about to change. I’ve started working part time for Jozztek electric vehicles so I really can’t be riding around with my bike held together with gaffa tape anymore.
Just to bring you up to speed, in the last few months I’ve pretty much demolished my rear tyre it may have something to do with the fact that it’s a super tacky Maxxis highroller and I’ve now clocked up over 300 miles of mostly road use. Time to splash out on a new rear tyre either a Kenda Krad or a DMR Moto RT maxxis are too expensive
I had my first LiPo die on me last week on my way to work , when I’m commuting I tend to pedal all the time and just use enough throttle to make life easy so I hadn’t noticed that the bike was down on power till I got to a hill when I stopped to check out the problem a couple of miles later I found that the pack was completely dead. And as I pulled it out of the box it puffed and was really hot. I was worried it would burst into flames but I was in a busy public place so I couldn’t stash it away and pick it up later so I had to put it in my backpack and use one of the packs that I take to do the return journey. I guess the lipo might have been a discharged one and got mixed up with the charged lipos by accident when I loaded up the bike oops.
Apart from that I must say that the bike has been super reliable (touch wood) and the only issue at the moment is an annoying creaking noise that the bike is making and I’m finding it difficult to track down the source. I should be able to find it / fix it when I strip the bike down to make the battery box. and Its pretty good at alerting pedestrrians that I'm trying to get past.
I’ve spent the past couple of weeks playing around with designs for the battery box in solidworks I’d been toying with the Idea of welding up fairings from sheet aluminium to enclose the frame but I wasn’t very happy with the complex angular look that it had so I’ve decided to revert back to the original plan of making fibreglass fairings similar to Keynes Giant DH http://endless-sphere.com/forums/viewtopic.php?f=6&t=26029&start=75
So in the meantime...
I’ve cut a load of foam blocks which I’ll use to mock up the battery pack for fiberglassing.
I’ve got my 36V and 48V power supplies from china which I’ll wire in series and can adjust to give me a total of 83V which should work out at 4.15V per cell for the pack then I’ll be able to charge the whole pack in one go in around 2 hours.
I’ve made up some busbars and adapted a couple of busbars that Jozzer gave me so I’ll be able to build the pack in its 4S 3P. And I’ve made some parallel balance boards so the packs should remain balanced to the ones they’re paralleled to. I added a tail so I can plug into a cell monitor/alarm which should help me keep tabs on things.
I ordered a 2m2 fibreglass kit this evening which should be more than enough to make the fairings.
Now should I replace the bearings when I dismantle the bike?... :?
