speedmd said:Should be a major advantage in the cooling department having it open. Do not want to think about what could happen if a spoke breaks when it is like that and the motor eats bits of it: :x
if the motor is open it will not improve cooling (much). two sidediscs will better emit heat i think.
i more bother about if some dirt / little stones get between lams and magnets..
flathill said:Maybe the joint won't be perfect and there will be a few hot spots but the stator will be fit into the Al ring frame and bonded in place. If you make the ring frame separate from the side panels/spokes the motor can be wound easy
yes i also think there must be a ring for lams which will be boltet to the other part of the case after wound. otherwise winding will be a torture..
edit:
hmm or maybe there is a way to leave a gap between the lams and the case sideways to keep winding easy?
a one piece case (at least on one side) would be better for centering the rotor (very consistent air gap). with a bolted case ring there could be some slackness..
