Fun looking bike
- ok im not a qualified sparky or anything so please double check me...
So we are switching the front and rear DRL (day light running?) lamps.
You could run them in serial with each other but that would result in both going out if one fails so i would suggest wiring in parallel with each other.
So
1) Connect the +ve transformer terminal to one wire connected to the red latching switch
2) Take the remaining switch wire and connect it to the +ve connections for both lamps (white for the front / red for the rear )
3) Finally you should be able to complete the circuit by connecting the transformer negative to the black/green (-ve) wires of both lamps.
If the switch is in the ON position the lights will flicker on, on connection, and it may even spark so be aware.
