A-DamW
🚴♂️ Mega poster
Pretty sure this one will fit a my1020(219 chain):Front sprockets are the problem with 219 chain and the my1020. They don't exist
Here is some good info on "Chordal Action":Ha I can see you have a strong opinion on it. I’m gunna try and fit the 114t I bought while keeping the rear brakes and 9t front. I’m gunna try to get more engagement with the idler sprocket too.
Thanks!Here is some good info on "Chordal Action":
That whole site has great info for all things chain.
Close, but no. MY1020 uses a 8x10mm shaft, that's for a 8x12 shaft.Pretty sure this one will fit a my1020(219 chain):
Do you have the chain to tire clearance to offset your rear sprocket towards the spokes a bit instead of adding an idler?I'm also using it in order to get chain clearance through the rear dropout. Or else with the large sprocket the chain is hitting the frame
An idler on the tensioned side of the chain needs to be mounted very securely as it’ll have a lot of tension on it. What idler and on what tube would u mount it so it’s running parallel with the chain? You said the chain would hit the rear brake so I guess you’d mount it to the seat stay, but that tube isn’t aligned and sounds awkward to do.
If the idler is to avoid the chain hitting the frame, I’d maybe even dent the frame if not much needed, which would be hard to do but surely could take it. If the idler is just to avoid the brake I’d take it off and do a regen rear brake and they can be plenty powerful at all speeds down to like 2mph and you’ll have a front brake too. I’d take the rear brake off and do the regen rear regardless.
I don’t think you NEED an idler to get more teeth engaged
I like how ur doing a giant chainring on the back.
That's a good pointDepends on tube wall thickness and butting. Regardless, it's an easy cheap precaution, with no downsides, so worthwhile.
The idler is likely to loosen the "U" bolt over time in some way.Is crushing the frame with the u bolt really a large concern? It's a stout steel frame and I try not to overtighten stuff
Only on the internet. That frame is probably straight gauge 4130. I'm guessing this is already a heavy bike, I wouldn't want to add any unnecessary weight. I can't tell from the pictures, is your idler bracket attached to/ part of the motor mount plate somehow? If not, it probably should be.Is crushing the frame with the u bolt really a large concern? It's a stout steel frame and I try not to overtighten stuff
I'll see what I can do. I figured stuff would get loose overtime. I tried to put lock nuts/washers or loctite where I couldThe idler is likely to loosen the "U" bolt over time in some way.
Secondary attach the idler bracket to the uni-strut in some way for piece of mind.
Weld, or small piece of angle with bolts ?
Battery box location looks better.
Center of the idler bolt is cantilevered from the center of the seat tube by 2" or so.I'll see what I can do. I figured stuff would get loose overtime. I tried to put lock nuts/washers or loctite where I could
Yes I'll have to see by how much, I thought it might. I also have the bracket butted tight up against the other motor mount strut and against the heat sink and was hoping that would help it stay rigid. But I'll give it a test and seeCenter of the idler bolt is cantilevered from the center of the seat tube by 2" or so.
Just a gut feeling based on experience, ~ Torque of the drive chain multiplied by the lever length will cause bending or twisting of some nature.
Haha that look is sick tho. Like a chopper. Maybe one day I'll change to 29" fork and then change rear wheel to 24"This is 26” wheels and a 29” fork with an excessive 180mm travel I think it was. I went to the extreme with picking this fork and it’s way too long and tilts the frame to a 60.9 degree headtube angle which is slacker than downhill bikes have.
Words from the wise ^So here's a story . . .
As a teenager, probably 14, a buddy and I were building a sand rail buggy and with realizing it we put the steering rack in upside down. Turn the steering left the buggy went right. Excited to try it out we pushed it out of the garage down the slope of the driveway. No engine, no brakes.
Neighbor just came home with a brand new truck with camper hanging of the back parked on the street slightly into the driveway.
The collision took the corner of his new camper off.
Dad is a volatile personality, luckily mom's home and hears about it first.
She says : I know I'll never stop you from building such stuff so if you promise to always do the brakes first I'll keep your dad calm.
Get the brakes done ! Both wheels !
Check / change the weight balance.
Most motorcycles I've ever owned had slightly more weight on the front. (Vespa style scooters being an exception)
Have fun.
