liveforphysics
100 TW
It seems pretty easy to find a Prius transmission for under $500 shipped to your door. Below are a couple examples:
http://cgi.ebay.com/ebaymotors/04-09-Toyota-Prius-1-5L-CVT-Automatic-Transmission-/200475947956?pt=Motors_Car_Truck_Parts_Accessories&hash=item2ead4c33b4#shId
http://cgi.ebay.com/ebaymotors/Proven-Transmission-2004-05-06-07-08-09-PRIUS-CVT-AUTO-/390234875891?pt=Motors_Car_Truck_Parts_Accessories&hash=item5adbcfa7f3#ht_2897wt_1165
Why would you want a Prius tranny you ask?
This is what they look like inside (an older version and newer version):
They have a place where the axles/CVs plug into them, so you would only need to make custom mounts and axles, and you could make any FWD car electric if you could figure out a controller that runs both motors correctly as they do in the clever CVT it uses.
Or, Honda Insight motors or Civic hybrid motors have a design that can be stacked as many as needed. 4 Civic hybrid motors all stacked together would be an 80hp continuous motor that could be capable of much more for bursts, and it all bolts right onto the civic hybrid tranny. Of course this option would require 4 controllers for the motors, bu those are also damn cheap. Then it would require the work of making them all controllable and play well together etc.
Insight motors are also thin enough, with the addition of some side plates for bearing supports, you could run one or two of them on a motorcycle.
http://cgi.ebay.com/ebaymotors/00-06-Honda-Insight-Hybrid-Electric-Motor-Engine-IMA-/270628124149?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f02b175f5#ht_686wt_939
Seems like perhaps a better option, or at least another option beyond the standard bolting up a brushed motor to a VW tranny with an adapter plate solution we've all seen so many times.
