eP said:For e-bike purposes ultra fine laminations are not so critical as for RC ones.
We don't want rpm in 20k+ or 30k+ range.
Miles said:Do we try to match Kv values?
johnrobholmes said:eP said:For e-bike purposes ultra fine laminations are not so critical as for RC ones.
Speak for yourself please, I will take a motor that spins as fast as possible with thin lamination's that have less iron loss. 30k rpm is nothing a gear can't take care of.
Personally I am not a fan of outrunners. I just use them for convenience and price. Try to switch them at too high of a frequency, spin them very fast, or use them in bumpy situations and they fail. Efficiency is lower than an inrunner too.
It depent on battery prices i suppose.So, is 6kW continuous the target?
johnrobholmes said:One thing that hasn't been mentioned is what happens when one system fails. If both motors are driving the same gear and one system fails, generally the other system fails too. ESC #1 frys, motor locks down, system #2 gets overloaded in a few seconds and the motor gets fried. Another issue is when one system "hiccups" and causes an out of synch moment. It can cause undue stress on the other system and fry the ESC.
eP said:I don't know why inrunners are better then outrunners in bumpy environment.
But i'm afraid high gear ratio gearbox for inruners will not be very efficient
too.
If i'm wrong let me know such efficient reducer from 20k+ rpm to 200 rpm.
Miles said:I'd assumed we'd connect them via overrunning clutch bearings.
johnrobholmes said:Miles said:I'd assumed we'd connect them via overrunning clutch bearings.
That would certainly remedy the issue. No regenerative braking for you!
I prefer freewheels over regen. I like going downhill fast.
Jeremy Harris said:I was thinking of around 6kW to 7kW as the target power, and making a compound motor that would deliver around 5kW fairly continuously.
recumpence said:You have to remember, I never ran motors that were too small. I always started with a motor that was adequate, but I wanted more. So, when I doulbed up the motors, I may have been running each below their ideal efficiency range.
That is one likely scinerio.
Ok. It could be an issue. But once again 8k rpm limit is still no problem for me. Maybe heavier (rigid) bell could adress the issue ?johnrobholmes said:Outrunners cannot be supported externally without an extra housing, there is only face mount available with exception to a few small motors. The front end of the bell is generally not supported either and will deflect when jostled. Some outrunners are available with a 4th ring bearing to keep the bell from flexing but it adds quite a bit of drag and limits the motor to under 8k or so. Flexing of the bell is generally the worst problem, and most manufacturers get around this by making a huge magnetic gap. I have destroyed so many outrunners from bell flexing it isn't funny, they are designed for use in airplanes and just don't take a bumpy environment.
Are you sure you get the same loss at each stage ?johnrobholmes said:A three stage gearbox is enough. The 3% loss in one gear stage is worth it to me. It more than makes up the efficiency difference between an AXI and a Nuemotor. Check out my build thread in the bicycle section for a rough sketch of what is being made.
Fumesucker said:A Castle Creations Thunderbird 54 is good for 54 amps continuous at 10 cells, which of course works out to around 500 watts or so.
eP said:Fumesucker said:A Castle Creations Thunderbird 54 is good for 54 amps continuous at 10 cells, which of course works out to around 500 watts or so.
It should works out to around 1500 watts i hope :wink:
Tiberius said:Hi Jeremy, hi everyone,
This is a very interesting topic, but 6 kW is serious power, is it not? I've just built a bike with 2 kW peak and that's fast. 6 kW opens up other possibilities. Some of you may remember a thread ages ago on electric hovercraft. Jeremy, are you thinking along those lines, or perhaps a flying machine? Or is this still for the motorcycle?
Nick
Jeremy Harris said:Suffice to say that if I can get a cheap, light and powerful multiple motor proof-of-concept going OK, then I will probably be aiming to build something a bit bigger than 6kW.............![]()
