Using RC motors on E-bikes [Archive]
Status
Not open for further replies.
johnrobholmes said:
I don't have a dyno to test of course, so finding out exact numbers of an efficiency loss in drivetrain will be difficult. Best I could do is a no load test and compare it to the no load amperage of the motor. Right now my drivetrain really sucks, so it will be a large improvement for me.
How about using a simple Prony Brake? It's something I want to try.
With wheels, Miles, although the yearning to convert my paramotor from 120cc 2 stroke power into an EV is strong............
I built a simple drum dyno a few years ago, using an old car brake drum. I just turned the outside of the drum smooth and made a half wrap friction belt attached to a lever arm and spring balance for the torque measurement. Cooling was by directing a trickle of water from a hose into the drum centre, which worked OK as long as you were careful not to get the belt wet. RPM was measured using a mechanical contact tacho, one of those ancient things with a rubber cone you press against the shaft centre. It worked well enough.
I may resurrect it for this project, if I can find all the bits.
Jeremy
You can use a very simple mechanism to dyno motors. Use something like a propeller to absorb the torque, which as Jeremy pointed out you can measure with a spring scale. RPM is no problem to measure these days.
Your "propeller" doesn't have to actually develop thrust, I made a whole series of different sized air movers with flat paddle type blades when I was testing motors a long time ago. A good quality hardwood that is free of knots and blemishes is fine for up to probably 10 kW or so. If you are really paranoid you can use aluminum plate.
Fumesucker- As long as you are expecting light assist the 3025 will work well for you. I have quite a few here and they are well built. You won't be able to hold it full throttle up a hill without gearing it 15mph or below, so be careful on throttle use. As for the longevity around bumps, that model does not have a ring bearing so keep an eye and ear out for scraping and wobbly cans.
I did some calculations with the ebike power spreadsheet and what you say matches well with the results I got, I'm taking that as a good sign.
I forgot to mention that after digging through my junk box (well, it's more of a large room actually) I found some toothed belt pulleys sufficient for about a 5:1 reduction, I'll probably try those out soon but I'll have to know the center to center distance before I can order a belt. Which basically means I'll need to have the motor in my hands before I can start designing the reduction gear system.
Jeremy Harris said:
I will probably be aiming to build something a bit bigger than 6kW............. :D
Thats what I had in mind also, mebbe six 5kW motors instead of a single 40hp motorcycle motor. That way you take advantage of more massly produced commodity items, like you said "distributed" sort of like a pc farm vs. a single super computer.
JohnRob,
Thanks for that info about bell deflection on outrunners. That was something I never considered. Now the $55 2kw 700kv inrunner I've been eyeballing is looking even more appealing, especially considering that forced cooling using water jackets becomes relatively easy with off the shelf. For me it's the low price for the power that draws me to an RC solution. If I'm going to spend $800-1000 for a motor and controller, then I'd just accept the 20lbs+ weight penalty and go with an efficient motor already proven to handle 5kw continuous and much higher peaks. I just want high performance at the most reasonable price, not the lightest or most efficient bike.
John
Jeremy Harris said:
Suffice to say that if I can get a cheap, light and powerful multiple motor proof-of-concept going OK, then I will probably be aiming to build something a bit bigger than 6kW............. :D
The key to this is avoiding the use of more than 75V DC, 50V AC......
Interesting point, that one. I notice the RC equipment tends to keep to 36 V or so, while a lot of e-bikers go to 72 V or more. It would seem at first that high voltage is better as it lowers the currents and the copper losses can be kept lower. In line with that thinking, I've gone for 72 V on the new bike.
But right now I am designing a DC-DC converter, and it is noticeable how the choice of electronic components goes down and the price goes up above 50 V. I'm having to review this idea that higher volts and lower current is best. In purely pragmatic terms, 50 V, 100 A may be easier to work with than 100 V, 50 A. Certainly if it is split into multiple parallel systems then it will be.
Nick
The low voltage RC stuff is definitely much cheaper than the high voltage stuff, massively so in the case of controllers.
I'm hoping to be able to make a reliable, efficient and powerful multi-motor and controller set up for much less than the cost of an equivalent single motor and controller. Hopefully it will be lighter as well. Keeping the voltage low doesn't present any real problems with the battery arrangements, as it just means breaking packs up into lower voltage sub-packs to supply each motor, rather than connecting them as a single high voltage pack.
Jeremy
Hi,
eP said:
I don't propose two motor setup for the sake of small diameter or weight.
Two motor setup is the best choice if someone want avoid super duper 200A amps ESC or the same level expensive 5-6 kW large outrunner.
Each one smaller motor is enough efficient for such case (two motor setup).
But the smaller motors generally have a higher RPM so you will need more gear reduction. The costs will probably outweigh the savings plus it will be harder to get set up. Consider the hoops that Scott and Matt had to go through to get their RPM's down far enough. Then consider what increasing the RPM is going to do.
eP said:
Controllers are different story.
They are so expensive as long as they are related to expensive niche motors.
They could become much cheaper as their parts are cheap now - if many e-bike folks would need them.
If most of guys would perfer two motor/ESC setup so twice of them would be wanted.
As a result prices should come down shortly.
The chances of a sufficient volume of ebikes using two ESC's to cause a price drop highly unlikely.
Probably more likely (eventually) is increased volume of RC motors on Ebikes will cause a reduction in the prices of big escs.
I decided to keep things between 36V and 50V. For ebikes, the appropriate gauges for connecting wires are easily manageable and it doesn't make any difference to the motor losses, of course. As long as you can find a motor spec. to match your needs, I don't see any advantage to higher voltages, apart from perhaps simplifying battery pack charging arrangements.
After much more head scratching I think I may have a handle on the multiple vs single motor gearing difference.
If you go from a single motor to a dual of the same power you should double your power, so all you have to do is use the e-bike spreadsheet someone kindly sent me to calculate the speed at double the power.
On level ground the spreadsheet shows 500 watts to give about 26 mph and 1000 watts to give about 34 mph.
So the gearing difference between a single motor and a dual motor setup of the same power to optimize for level ground should be 26/34 or 0.765.
A Scorpion 4025-10 turns 5144 rpm putting out 500 watts at 12V and 50 amps at an efficiency of 85%. For a vehicle speed of 26 mph with 20 inch tire that requires a gear down of about 11.6:1.
With two identical motors your gear ratio for each motor should then be 11.6 * 0.765 or 8.87:1, if you are optimizing for level ground.
With three identical motors the top speed on level ground would be 43 mph so the gearing would be 26/43 or 0.604.
Which gives us a gear ratio with our Scorpion example of 11.6 * .604 or 7.01:1.
For hill climbing I think the ratios will move somewhat closer to .5 for the dual motor and something under .5 for the triple. I'll work that out in a while.
It would be very nice if this proves to work well for our application. I have been avoiding double motors because of my experience with twin motors in my RC models.
If multiple motors proves to give close to double output in bikes, it opens up many more options.
My skill is in mechanical design, problem solving, and machining. So, making the drive system is no problem for me. I fall down when it comes to the electronic end.
I am looking forward to how it proves out. :D
Matt
I checked and the ratios for a ten percent grade were so close to 5:1 and 3.3:1 that in the real world it would make no difference.
Fumesucker, this one doesn't sound right.... Wind resistance goes up with the square of the speed - power to overcome it goes up with the cube.... What proportion of the 500 Watts is your wind resistance power requirement?
Interesting motor in that link, Miles. Be nice if motors like that were to become available retail, but somehow I doubt that they will.
I've been doing more motor and controller comparisons, to try and work out the "best bang for my buck" for a multi-motor proof of concept system, but without opting for anything too cheap and nasty. I can't afford to risk megabucks on something that's state of the art, either.
I've come down to a selection based on four criteria; continuous power, total price for a motor and controller, watts per kg and watts per £. The short-list of motors is:
Tower Pro 5330 10T - 80A max, 60A best eff, 215kV, 679g, about £25
HXT 73-64 - 75A max, 60A best eff, 200kV, 790g, about £35
HXT 80-85A - 125A max, 110A best eff, 250kV, 1230g, about £75
The choice for affordable controllers comes down to just one or two, although they seems to be supplied under several different names and prices. The one I've opted for is supplied by http://www.budgetrc.co.uk and seems to get reasonable reviews (it looks like it's also sold as the Turnigy Pentium and a few other names). It will handle 125A max, 100A continuous at up to about 28V and costs around £30. I opted not to use the very cheap "super simple" controller in the light of the comments here about it being a bit flaky.
The benchmark comparison figures for each of these motors and the above 100A controller, when run from a 24V supply, are:
Tower Pro 5330 10T - Continuous power = 1920W, total price = £55, watts/kg = 558, watts/£ = 26
HXT 73-64 - Continuous power = 1440W, total price = £65, watts/kg = 635, watts/£ = 22
HXT 80-85A - Continuous power = 2400W, total price = £100, watts/kg = 565, watts/£ = 24
Despite the higher power of the HXT 80-85A, the best motor in terms of price, power per £ and power per kg looks to be the Tower Pro 5330 10T, so it looks as if that will be the one.
All told, building the spreadsheet to compare lots of motor/controller combinations has been interesting, as it's highlighted the impact of the motor and controller specs when combined as a system.
Jeremy
Hi Jeremy,
Might be worth investigating the larger motors here: http://www.suppomodel.com/ Maybe you would get a good deal if you ordered a couple, as samples, direct from the factory.....
Available in UK, here: http://www.allelectricrc.co.uk/suppo-motors-108-c.asp
Thanks for those links, Miles. I'd taken a look at the Suppo site before, but couldn't find any detailed info or prices, so hadn't really considered them as an option.
I think I may go for the TowerPro motors for my experiment, unless I can get a good deal on a big Suppo and suitable controller. There's a part of me that suggests going for the more expensive, more powerful, HXT though.............
Jeremy
Miles,
Many thanks for that link, it's very reassuring to read that review on the motor, although the link is broken, I managed to dig out the test review from the HobbyCity forum. There are some other good reviews on that forum, too. Here is some of the text of the Tower Pro 5330 review that I've cut and pasted:
Tower Pro 5330 is definitely one exceptional motor that will make all it's owners very happy campers. Strangely enough, for me it was totally unfortunate from the very beginning: I have built very nice Zlin 526 powered by TP5330 that crashed on it's third flight (see the photo gallery here: http://www.pbase.com/miljenko/zlin526 ). And yesterday, during the last test in a row it tried to kill me and almost succeeded. Both events were all my fault but nevertheless I'm approaching this motor now with great respect.
http://hobbycity.com/UNITEDHOBBIES/store/uh_viewItem.asp?idProduct=4572
Although it's dimensions (63 mm dia and 70 mm firewall to prop length) do not reveal how huge it is, when you grab it, 730g of total weight (including X mount and prop adaptor) and very solid construction gets you immediate feel of power and ruggedness.
There are actually three version produced having 8, 9 or 10 stator winding turns. The one tested here is 8-turn variety, having declared Kv of 259 rpm/V. After 5 props tested and all the measurements performed, it was easy to calculate all important parameters which are:
Kv = 254 rpm/V
Rm = 24.5 miliohms cold, at 1A
Rm = 63.4 miliohms at 70A, warm
Io = 1.5A @ 7V,
1.9A @ 10.5V,
2.2A @ 14V,
2.4A @ 17.5V,
2.6A @ 21V,
2.7A @ 24.5V,
2.8A @ 28V,
2.9A @ 31.5V,
3.1A @ 35V,
3.3A @ 38.5V,
3.5A @ 42V
Spreadsheet that was here won't copy into the post on the forum for some reason
Other than that, this motor provides enormous output power. It copes with 2500W+ power levels with ease. Efficiency remains high; between 81 and 86% for all currents from 25 to 72A.
At 10 Lipoly cells (2200 mAh Hextronik's wired in 10s4p configuration) this motor responds fluently to loads up to 72A. When equipped with 19x12 APC-E prop funny thing happens above, say 7/8 throttle setting: motor suddenly produces weird sound and stops. Scope check reveals stator core saturation producing abnormal load to ESC (OEMRC Sentilon 100A HV in this case) which decides to shut it down. That is why all the 19x12 related figures are marked with asterixes, meaning those were achieved at less than full throttle.
However, I was flying my Zlin with this prop with success thanks to the fact I have used full throttle only when the plane was in the air and already having pretty high speed. Due to prop unloading, current obviously wasn't reaching critical value so no esc shut down appeared.
Now back to the chart. Violet percentage figures suggest that shaft power (net power delivered to the prop) almost equals electric power entering motor wires. Values calculated were derivied from prop manufacturer's "n100W" values for props used. It is RPM value that prop produces when driven at 100W net power. When knowing this very useful figure one can get exact shaft power after measuring rpm value.
Well, the above is true IF the prop keeps it's characteristics at given rpm. And it does in case of Aeronaut CAM Carbon props when used within allowed loading. This time I failed to notice rpm's went out of safe rpm range and that is marked in my chart as red rpm figures. All 17" props are limited to 8000 rpm, while 18" are allowed up to 7000 rpm by manufacturer. Obviously, I was way above declared values where props lose their characteristics and became dangerous. So unrealystical efficiency figures shows that prop fins begin to bend torsionally, loosing it's pitch and loading less than predicted. How it ended, read in the blog article following this one.
Other than this unfortunate event, I am extremely happy with this motor, searching for another project where it will fit in. However, this time it will be fitted with carefully selected propeller.
Published Nov 01 2007, 01:51 PM by Miljenko
Apart from the odd effect when heavily loaded (which might need some looking at in a vehicle application) this motor looks to be good value.
Jeremy
edited to add:
Whilst digging around in the link Miles provided, I came across mention of the Double AXI 5330 motor. This is two AXI 5330 motors mounted on a common shaft and driven by two controllers. Googling around found a few useful snippets that show that this arrangement does give double the power of just a single motor, which is reassuring for my idea of coupling motors together.
Jeremy
Good catch, you're right, I misread something apparently.
Note the "Performance by KPH" and "Resistance breakdown" sections.
26/39 is 0.666
I thought it must have been something like that.
How are you getting on with the spreadsheet? Let me know if you have any suggestions for improving it. I've got several ideas, but not that much time to devote to it, at the moment...
A "Watt hrs/mile" and "Watt hrs/km" readout would be nice.
Very informative piece of work, I've enjoyed playing with it.
On edit: A "Human Input" option would be nice too.
Good ideas. I had the "Human Input" option in mind, already. A "Headwind" option might be useful too, perhaps?
I didn't write this but I have tweaked it a bit, and have always intended expanding it. If anyone else wants to help, then....
The lower the KV the easier is is to deal with, well at least gearing. A nice thing about this is you can use the shaft on the mounting plate side like Scott did already. http://www.endless-sphere.com/forums/viewtopic.php?f=6&t=5168&start=0
I would love to use this!
Model: HXT80-100-B
Wire Turns: 8
Resistance: 32ohm
Idle Current: 2A
ESC Required: 130A
Input Voltage : max. 48V
Kv : 130 rpm/V
Weight: 1570g
Shaft: 12mm
Voltage Range: 20-48v
Non Load Current: 2.0A
Maximum Power: 6500W
Equivalent: 60-80cc Gas Engine
Yes, a "Headwind" option could prove useful.
And I agree that the lower the KV, the easier the gearing becomes.
Status
