recumpence
1 GW
Thanks for the input.
I do not mind spending upwards of $1,000 on a motor if it will do what I want.
The Lehner inrunner would only be run at far below its design output (maybe an average of 600 watts for this 11,000 watt mootor) with the occasional 18,000 RPM, 6,000 watt blast. So, I am not too worried about heat build-up. (Oh, I am not sure you can get the 3080 with a fan, I think the fan is only for the 22 series motors).
My AXI is a 63mm wide motor. I only have about 70mm clearance total. the Terminator is 77.5mm diameter. I would have to do alot of machining and modding to make it fit, but I can do it. The lehner is 60mm wide. It will fit right in. Even the bolt holes are the same location as my AXI. Besides, I would be running the Lehner at far below it's rated capacity. However, that being said, even with a low KV, I would be running it at an average RPM of about 7,000. It would be run as low as 4,000 RPM at times and as high as 15,000 to maybe 17,000 RPM for short runs at top speed.
However, that being said, I do not mind doing the machining deeded to make the terminator fit if that is the best option.
Matt
Matt
