lazarus2405
Bleh.... because on my unit I have error code 5. Whatever the heck it means...
Time to look for shorts on the low voltage parts... *sigh*
Update: After changing fuses, and finding that I had a bad connection in the holder, it seems that the controller has changed its mind from "Electric current failure" to "MOS damage". It seems that that error code refers to a "volts but no amps" situation, like Link experienced, caused by a high resistance connection.
So, "MOS damage". I suspect that it is detecting a short somewhere in my high voltage side, most likely a high resistance path (since I didn't find any obvious ones).
So, can anyone tell me what I should expect resistance values to be? B+ to B- should be no connection. What about between each battery pole and any phase, or between two phases, and between various FET legs?
