Is there any special controller for GL dual speed motor?solarbbq2003 said:when switching windings make sure throttle is in off position, if motor is under load the analog controllers could be damaged, assume same for digital type, there was lengthy dicussion about it on 'power assist' yahoo forum, one solution so could switch when under load was too use voltage suppressing diodes, to stop the back emf spike when you disconnect a winding.
monster said:anyone know what to replace T5 with? part number?
solarbbq2003 said:the abs pin on the board is for regen braking ( not related to reversing function),
it uses the inductive method I assume via pwm to induce back emf for the regen current.
Simply have to put a wire from the abs pin to one of your brake handle cut off switches and another wire back to the ground connection pins in right hand bottom corner of board and you have regen braking when brake handle is applied.
I think its not a very efficient method of making regen but makes a hell of a good brake, will hardly make any difference to range unless you start getting into supercaps.
Thanks, fechter! I placed an order with Allied Electronics for six 4110s. They have them for $5.13 but they didn't have stock for the PNP transistors. I think mine are okay so, hopefully, I won't need them. I decided to upgrade to 4110s. Hopefully, they'll hold up better than the 4130s for me because I don't want to wager the expense for a full set of twelve FETs--at least not until I know the controller can be saved.fechter said:OK, T5 looks like a PNP high side driver.
This is the highest recommended mod because one main cause of the failure of V2 is the "weak traces" and "plated holes" for high current paths, especially when using C5000 motorsDeepkimchi said:Add solder or wires to all the famous S (source) connections hidden by a painted over trace.
Deepkimchi said:So after going thru 15 pages, is this the final list of mods I need to do ?
Add a pee detector pad from the bicycle seat to the controller, which shuts down system at high speeds?![]()
solarbbq2003 said:basically just have to connect abs pin to ground to get braking effect,
normal on/off switches in brake handles needed ( not electronic type that have three wires from brake handle)
just two wires from brake handle, when brake squeezed switch completes circuit of abs pin to ground, can use any switch really. Braking effect depends on alot of things, how charged batteries are, speed etc, not sure if will work on higher voltages, not sure if there is a max voltage cut off in the regen like other regen controllers which usually cut off at 60v to protect 48v sla batteries from overcharging.
but makes a powerful brake
