VESC Regen question
ak136
⚡ Regular
Hello,
I have a flispky 75100
Regen braking is very good I can drive my cycle without touching brakes
When current is positive battery current follows motor current
But during regen braking when current is negative battery current for a brief time folows the motor current and then goes to 0. So where does the current go?
Couple of different max current values I have sent from different liga
I'm not familiar with this software but i'm familiar with VESCs and this controller is kind of a ripoff of it so..
From a seat of the pants feel, does the regen start and then cut off after a short period of time?
Negative current would go back into the battery ( if regeneration is happening )
The VESC short-circuits the phases for full break, if the speed or the duty cycle drops below a specified threshold. The current is just circulating in the motor then and is not pushing back energy to the battery.
Hey @stancecoke
Thanks for answering
Where can I find the specified threshold? And what would be way that I could increase the regen current, I would rather that I can recuperate all the energy back to the battery when braking
Hello, sorry I didnt see you message before
This is vesc tool Log Analysis
Mybe I can feel while riding little the shift from battery regen and then switch to motor regen or mybe its just me halucinating
I just want to increase the regen current going into battery
Right now my battery max regen current is set at -40A, is this too low? Should it be positive value in the vesc tool?
And when I think about it more mybe my battery is stopping charge after it senses too high charge current
My bms is common port, when I think how common port works by having a bidirectional switch with two mosfets placed in antiseries it would be possible to stop charge current flow but still alow discharge current
Mybe I try regen braking with unprotected battery just no load testing at low battery soc
