I have a 48v 1000w motor and a 48v 13 ah battery (which has a 30amp bms)
I have a Flipsky 75100pro V2 controller which I am just trying to setup
On the settings page I have set my battery amp to 28amp to keep the battery safe but just wondering what should I set the motor current Max value at? and also the absolute motor Max current ?
When I ran the Vesc setup test it says my motor current is 86.76amps
So in the Vesc app should I set the motor max current to about 85amps? Or should this value be much lower if I only have a 30amp bms on my battery?
Also what amps should I set the absolute max current to?
