dogman dan
1 PW
Here in the USA, the disconnect is supposed to be automatic. But doing it manual would be safe, even if illegal. I agree, a lineman that stupid deserves to toast his hands off. I think the issue may be that your power could also be entering the neighbors house, who may be touching stuff like an idiot while the power is off. If your drop is connected in the same place as your neighbors, that is. I have three neighbors that way.
At my house, my main disconnect is not built to conveniently do it. Basicly, the panel is not built for it to connect power in a different way. But something could be added. Since my generator is too small to power the entire house, I'm using extension cords run through the dog door for now. I've been thinking of running a second set of wiriing in the house. One plug in each room, that would be energized by plugging the generator to a male RV plug on the back wall of the house. So on the back wall, I'd have the same plug you see on an RV, leading to a box, with three 15 amp breakers. Run about three plugs per breaker. I'd be able to have a fridge plug, and a couple plugs by window AC's, and plugs near the tv's and computer.
I fail to understand how sufficient power would be different, whether from a generator or a house plug. You either have the amps, or you don't. 30 amps on a short fat cord from the generator should do it. I think the size he bought will be big enough, once he plugs into the 30 amp socket. For sure, if the garage plug is a 14 guage run of 40' of wire, to a 15 amp breaker, then you have problems.
