Thanks for the info..what I meant by in-line is putting the purple wire into the brake light circuit if you will.
But *where* in the brake light circuit?
And is it being wired in series with it, or in parallel with it? (series means breaking the original connection, and placing the new circuit completely between them; parallel means just connecting one end of the new circuit to the original connection).
It’s a drum front brake with a drum style brake switch. It’s a two wire brake switch. One wire gets 12v the other is a ground. It seems from what I’ve been reading most circuits that use a brake light in the circuit should use the high brake wire but being I have a two wire brake switch this makes me believe it should go to the low side as there is a ground wire in the mix.
You'd have a two wire switch regardless of how it's wired or which way it works.
Doesnt' matter what kind of brake it is. Only matters how your brake light works.
(BTW, if you have a switch with 12v from the battery on one side, and ground on the other, it will just short out your battery when it is turned on, and either damage the wiring, start a fire, pop the fuse, or some other generally bad thing...so your switch must be getting it's 12v from somewhere other than the battery--you should draw yourself a diagram as you trace it out to be sure where that is, so you will know for later, in any troubleshooting, if there is no diagram for the system to start with).
Regarding brake high vs brake low on a controller--most of the brake low stuff I've seen uses the controller 5v internally to pull it up when it's not being grounded. If you connect that to a 12v brake light circuit, you'll probably destroy the controller by feeding 12v into it's 5v power supply and all of the 5v parts everywhere in the system connected to that may also be destroyed (throttle, etc--motor halls might be safe as those are often good up to 20-30v, but not all of them are).
So, how is your *brake light* wired to this switch? That is the thing that you must know for what kind of input your controller will get from it, and thus whether it will work or not.
If your brake light is wired so it always has 12v to it on one side, and one side of the switch to the other, and the other side of the switch to ground, then if you connect the brake light signal to the controller that expects 12v to turn on the ebrake, it will always have the ebrake *on*, *except* when you pull the brake lever, when it will turn *off*. (opposite of what you want)
If your brake light is wired so it always has ground to it on one side, and one side of the switch to the other, and the other side of the switch to 12v, then if you connect the brake light signal to the controller that expects 12v to turn on the ebrake, it will always have the ebrake *off*, *except* when you pull the brake lever, when it will turn *on*. (what you want)
If the controller's brake input expects a ground to turn on the ebrake, then the first example will work, but the second won't.
