Hello, I'm now getting my electronics to complete my scooter that I'm upgrading with an outrunner and I am going to implement temperature control. I bought sensors for the controller and the motor but now I need to know what a recommended maximum temperature should be! I was thinking about placing the sensors on the motor's coil(The magnets are moving, so those won't do it.) and somewhere on the controller where it gets hot(like the mosfets, most likely).
So, any ideas? While motors running at a lower operating temperature are obviously better performing, it obviously can't be too low or the performance of the motor would be limited much more than it would at a higher limiting temperature. But, at the same time, I kind of want to protect the motor and controller from over-heating as a result of adapting it to something it wasn't designed for(and, in effect, abusing it.).
The motor is a standard HXT motor 2-pound 230-kV motor that'll draw approximately 30-70 amps continuously and the controller is a Castle Creations Phoenix HV 85 amp controller.
