amberwolf said:
If you mean like the one held out in this pic:
http://www.endless-sphere.com/forums/download/file.php?id=54873
then you don't need them if you have torque arms. They're really only good for low-torque/power setups, like my Fusin started out to be (before I went from 36V to 48V
). Past that point, the torque arm is gonna have to do the job, cuz that little tab on the washer wont (as I already found just with the Fusin).
On my setup using Justin's torque arms, that "D" tab washer is a spacer that allows space for the torque strut. In terms of the tab, it is redundant as the torque arm really carries the load. Here you can see the torque arm and strut. The "D" tab washer is at the same level as the torque strut:
Here's what I plan to do on each side with the new 6x10 motor:
0. Motor axle with "D" flats and thin shoulders 15mm axle/14mm threads/10mm flats (Nine Continents)
1. Thin "D" washer (approx 2mm) (ebikekit.com InsideSafetyWashers)
- to spread load from thin axle shoulder onto the alloy dropouts
2. Flat aluminum alloy rear dropout (must be flat for full contact)
3. 1/8" thick "D" washer (tabbed or not) (ebikes.ca SpaceWasher14)
- torque strut is also at this level
- the tab is not important, this is a spacer, the torque arm and strut take the torque load)
- this does not have to be a "D" washer, but one is preferred
4. Torque arm 5mm (ebikes.ca TorqArmRev2)
5,6. NordLock (tm) washer pair (do NOT use any other washers with NordLocks, it will defeat the lock)(mcmaster.com 14mm)
- the materials on either side of the NordLock must be softer material than the lockwashers for them to work properly
7. Nut (came with wheel)
NOTE - I do not use the torque strut that comes with the torque arm. Instead I fabricate a new torque strut that has precisely sized and spaced holes for zero play. This strut goes from the end of the torque arm to an existing threaded hole in the dropout. In my case I don't have room for the torque strut nut so I thread one of the holes directly in the strut. I used 1/8" by 1/2" 6061 T6 for the struts, of course steel would also be fine. The stress here at one inch from the axle is a lot lower than it is in the arm at 7mm radius, so we can use aluminum for moderate performance hubmotors such as this. Steel would be indicated for higher performance hubmotors, or extreme current applications of this hubmotor.
NOTE - do NOT use flat washers adjacent to the NordLock lockwashers. These lockwashers must contact the nut on one side, and something that can not rotate on the other side, such as the torque arm, a "D" washer or the dropout.
The NordLock lockwasher pair is a special locking washer that is very effective at keeping the axle nuts tight. Since this is so critical for a hubmotor I felt it was worth using a somewhat special high quality locking solution. These lockwashers are not that expensive, but they are also not available at the hardware store. I ordered mine from McMaster Carr online. NordLock washers work by having ramps on the side facing each other, and teeth on the opposing side that cause the nut to tighten slightly as it is removed before releasing tension. This places the system in a "valley" so that nut rotation in either direction increases tension, and this prevents the nut from rotating. Essentially it is stuck in a notch. These are removable and re-installable for easy servicing without loss of locking functionality
