Supreme Kay
Hello Ebikers
I own an e-bike with a 1000 watt motor, 25 amp sinewave Controller and a 48 volts- 11.6 ah battery made of Panasonic NCR18650F, my battery has a 30 amp BMS. I mostly use the throttle on my e-bike mostly to get from my home to work and back from work to home. That is about 10 miles in total, I live in Tallahassee, Florida.
My battery case is a hailong (Down Tube) you can see it here:
https://www.aliexpress.com/item/Down-tube-electric-bike-battery-case-and-lithium-ion-storage-box-for-36V-or-48V-electric/32796605576.html?spm=a2g0s.9042311.0.0.7ijUVj
I am considering placing the fuse (fuse holder with the fuse inside) on the positive wire coming from the battery case stand that connects to the controller of my e-bike. Can you please suggest a fuse holder and fuse that would work fine with my e-bike. So far this is what I found:
Bussmann BP/HHG-RP Fuse Holder
https://www.amazon.com/dp/B004AH4PXW/_encoding=UTF8?coliid=IY3J3PMRWI3JX&colid=3MEKWL18BSRP9
Thank in advance for your input!
