WoodlandHills
While I agree that a DD hub is the best choice for this poster, I have to rebut a few of the criticisms of mid-drives offered here.
Rapid wear of chains and gears is a function of the chosen bicycle and NOT the mid-drive. Put a mid-drive onto a bike with an internally geared hub and the chain will last forever and so will the gears, put the same mid-drive onto a bike with a derailleur and 10-speed chain and you have a problem. It has nothing to do with the drive and everything to do with the bike.
How is it harder to install a BBSxx drive than a hub motor? Take off the BB, install the drive+brake levers and lengthen the chain if necessary vs removing the rear wheel, figuring out how to attach the torque arms and (possibly) a new freewheel cluster+shifter and bolting it all together. Seems like a wash to me; if anything the mid-drive is a bit more plug and play, if you are installing a Bafang......
