I have a thought for a rear hub that could be machined. It would be the standard 135mm width, with a disk mount on the left side, but with enough threads on the drive side to accomidate two freewheels. I would then use the inner freewheel as the e-drive, with a big sprocket on it (44-46T), and the outer freewheel would be there for the pedal drive. The reason for this, is that it would eliminate the need for a freewheel at the cranks, and one on the drive sprocket. I am working on drawing one up in Solidworks, but I need to know what the dimensions are of the freewheel threads.
Does anyone know these dimensions, and also, what do you think of the idea...can you see any problems with this design?
Thanks,
--Ryan
Thanks,
--Ryan
