warrah
Basically i added a thermistor to the cromotor recently, and while removing the motor from the frame i noticed that one of my custom 8mm torque arms had slipped slightly from where it was attached to the chainstay. I checked if this meant torque arm failure, and found the torque arm holes were still very snug. I couldnt work out why the two torque arms were now out of line with each other, and assumed that perhaps one of the chainstays had actually bent or something. Oh how i wish, that would have been much cheaper. Instead, when you compare both sides of the axle, the two sides are no longer aligned, in the sense that one side has rotated so that its flats are not facing the same way as the others. When you inspect each side individually, there is no evidence of rotation, each side alone is untwisted, meaning the twist must have happened somewhere inside the stator.
Im afraid its very difficult to show with pictures, every time i try to take a picture of the wheel facing forwards to show both sides of the axle for comparison, the camera focuses on the tire.
Could i just weld two slightly out of line doctorbass torque arms to the dropouts and keep riding, would that be safe or is there serious cause for concern? Can axles be replaced?
