I'm not sure why wb9k is being so negative against the taobao supplied cells.
He says they are
Once again I disagree with this view, considering the price of these cells compared to new cells, and the fact that you can buy them with good IR and capacity, its a bonus to ebikers that they are available ( you need a contact in china to organise buying them). The negativity against tabs that have some plastic rubbed off is I feel unjustified. It can lead to shorting with quite small currents involved, there was only one cell in the pack that had a shorting issue anyhow ( out of 16cells) and the solution to this shorting is so simple ( just a smear of silastic on the edge of the cut plastic)
I did quite a bit of searching on taobao to identify a supplier that actually tested the IR/capacity of the cells before buying them, from memory the price was 80rmb per cell ( approx $12usd, current prices vary from 60rmb $10usd upwards). The issue now is how to get the cells out of china, as its becoming increasingly difficult to send them out of china.
If you buy from a random chinese supplier of the secondhand cells there appears to be very few that actually take the time to test the cells, so its hit or miss, hence the need to do some research at the chinese end.
The source of the cells appears to be large ev packs but its not known by me what program in china is releasing the packs.
They are 100% used packs, but if you can get a hold of cells that still have good IR/ahr ratings why not use them?
So how about wb9k instead of being negative about these cells, how about back up your statements with sound reasons why you think they are "reworked trash", purely negative speculation is not useful in these discussions.
My guess regarding the source of the cells is either
1. after a given time ( one or two years) period the packs are replaced regardless of condition
or
2. more likely, one or more cells fail in a pack, rather than replace the bad cells the whole pack is replaced and those packs
sold off cheap to be taken apart and reused by small businesses, perhaps how victpower is sourcing its cells.
If whole packs are simply replaced with new packs, rather than identify bad cells and replace them, it would suggest a
govt funded program ( perhaps electric buses or taxis).
Either way there are going to be plenty of good cells in these packs. Its unlikely we'll ever know the true source of these cells.
With regards the cell that had a short, it was located in the middle of the pack I built, I noticed its voltage was always lower than the other cells ( when I built the pack I did for a time actually monitor voltages via cell log). Once I removed it from the pack I noticed I could make a tiny spark puting a screwdriver on the edge of the cut plastic on the copper tab, this was the source of the leakage, the aluminium on the mylar outer casing ( being in direct contact with the aluminium tab as there is no kapton tape used on that tab), the cut plastic allowed the mylar aluminium to contact the copper tab. A smear of silastic stopped the problem. I just tried to measure the resistance of the aluminium of the mylar type pouch, its hard to get a stable reading but appears to vary from 2 to 60ohms, that would allow quite high currents to flow via the mylar type pouch aluminium if shorted to the copper. Quite surprising I didn't think it would have thought it would have a higher resistance to current flow. Anyhow the silastic method worked well to solve the problem.
