oatnet
I wonder what is limiting your top speed?
Between the upright seating position and the "freeradical" bags flapping in the air, my xtracycle has more drag than Hollywood blvd.
-JD
Now that is funny! :lol:oatnet said:...my xtracycle has more drag than Hollywood blvd.![]()
Floont said:Hmmm... At 88.8V, a 5304 should be getting significantly higher speeds than my 5304 at 72V, although my highest speeds are on a fresh charge and the batteries are really at 78.2V (plus my tires are over-pressured to reduce rolling resistance). Today, I hit 42MPH on a flat road, no wind. The 42MPH is verified by GPS.oatnet said:...44.7mph on my xtracycle with a kelly driving a 5304 at 90a from 88.8v/15ah LiFe...
Doctorbass said:UPDATE from july 2010:
MAX speed ON FLAT * Doc reached: 6 6 . 0 m p h (106kmh)
using 10.8kW continuous for 30 sec
MAX speed UP HILL ** Doc reached: 5 4 . 6 m p h (88kmh)
using 12kW continuous on an X5 for 10 sec
<snip>
Doc
I am in awe!Doctorbass said:...
using 12kW continuous on an X5 for 10 sec...
Floont said:I am in awe!Doctorbass said:...
What voltage are you running - 100.8v?![]()
What gauge power and phase wiring do you use?I can't get close to your power levels out of my 5304. When I approach higher amps (>100), my voltage drops - expected to some degree, but not to the levels that I am seeing. It seems to be pointing to insufficient power and phase wire sizing or connector losses.
FA
I use a front x5304 already. I have one strong steel torque arm on the left side of the front fork. I'm thinking of adding another for the right side since I've been incrementally increasing power (and speed - I'm up to 47MPH pre-wreck). When I started this hobby, I wasn't into acceleration at the time, thus the front hub motor.Doctorbass said:You dont need dual X5 to get these performance level :wink: .. Dual X5 mean one on the fork and i would avoid that unless you make a STRONG fork and dropout... otherwise the result could end up to make you have to upgrade your avatar pics for a worst case!
I concluded my main problem is that I'm using SLA batteries which really can't do more than about 55 amps sustained. I can get a burst of over 100 amps out of them though. I'll be upgrading the batteries soon.Doctorbass said:Yes i'.m using 24s lipo 15Ah battery and the CA read often above 200A burst during fast speed or hard acceleration.
My power and phase wiring are a lighter gauge, but I can't remember... I'll have to check it. 8 gauge is nice and beefy and I'll check into those connectors. Mine look like their rated for 30 amps which is terrible!Doctorbass said:i'm using 8 gauge wire cause i wnted a setup as light weight as possible. I have 6 gauge, 4 gauge and up to 3/0 gauge from old car audio SPL projects... but it's to heavy.
I also use the great PP75 powerpole connectors and a 18 fets doc modded controller as well.
Doc
I assume you mean a new avatar, not a new picture of how much I have healed since the wreck. Since Photobucket has removed the photo for no apparent reason (it doesn't violate their terms of use), someone must have complained about it; it's probably a good a time as any to change it soon.999zip999 said:Hey floont, How about a fresh pic.. Are you running a alumiun bike with the batteies on the top of rear rack ? Maybe a full face helmet next.
dogman said:New top speed on the racing bike. Now at 24s lipo, 101v, 46.5 mph, 45 going back on the same road, so call it 45.
Not drag race speed, but pretty fun.9c 2807 motor, Lyens 12 fet controller stock settings (40 amps), 24s 10 ah 30c turnigy battery.
Time to drill some holes in the covers. 8)
Yeah, ridng it with a motorcycle helmet. And two pair of pants, and gloves with carbon fiber knuckes.
Kingfish said:Update:
Thinking, perhaps too deeply, I presume the OP was talking about bicycles![]()
Impressive John! What is the freewheel?John in CR said:Kingfish said:Update:
If that's case then I'm the only one with a street legal bicycle, so you guys must be recording your speeds on dirt paths. My "bicycle" hits 60mph regularly with a hubbie in a 20" wheel using a 20s Konion pack sagging to 75V or less.![]()
dogman said:26s on the racing bike got me 51.6 mph. But that was on a very shallow downhill. About 48 mph once I average in a return the opposite direction.
Gonna have to pop a quick run at 28s, just to get legitimately into the 50 mph club. Gotta do it when roads are pretty empty, except for occasional test runs, or lower voltage riding this race bike is a track animal.
Man, just small ripples in the pavement are REALLY felt at 50 mph on a no suspension race bike. No frame flex issues though.![]()
TheKraftyRhino said:165MPH 7 seconds in the 1/4 mile.............................
http://www.youtube.com/watch?v=8l0bxRu81IA
JK but would be cool if that was my E-Bike
