dogman dan
1 PW
The short answer is in my signature, but it needs updating. Running 120 volt controller now. Full details here, http://endless-sphere.com/forums/viewtopic.php?f=6&t=18644
Floont said:.
This morning, I finally exceeded 90 kph today on the flats, no wind, temperature 68F, and achieved a speed of 57MPH.![]()
I attempted a second speed-run, but melted a 30amp connector on my 2nd acceleration.![]()
Time for me to go into a soldering frenzy.
FA
Fortunately, when I designed my power system, I put a lot of 50amp Anderson connections to/from each battery bank. I carry an Anderson 50 amp jumper with me just in case there is a battery fault. Today, I used it for the first time. My bike went from 132V to zero, then back to 72V after I jumpered past the burned-up battery pack connector. So... I got to cruise on back home at ~35MPH. Thank you jumper!icecube57 said:...Ive had those moments where I end up pedaling home...
I calculated that my connector failed while I was pulling about 6KW through connectors that were never rated for such current.icecube57 said:I'm dumping anywhere between 3500w to 4500w into mine and try to back off around 2000w. I haven't had a failed Anderson or warm connectors. I guess the phase current is a lot lower than when I had the 5303.
Not to belittle these great achievements, but for more perspective, Sam Whittingham hit his record in a custom aerodynamic shelled recumbent bicycle and given what they call a "flying start" through a 100 meter flat course to attain his record.John in CR said:For a bit of perspective Sam Whittingham hit 82.8mph on a flat road, and Fred Rompelberg hit 167mph on a flat road drafting a motorized vehicle. Both were with only a human motor. http://en.wikipedia.org/wiki/Cycling_records
