Hey Dudes,
I'm building x2 13s 10.4ah packs with a single BMS.
I want to connect each of the 13 cells in parallel with the other pack so the BMS will monitor the pack as a single pack (which it is what it actually is when it's connected like that).
My question is how thin can I go with wires that connect each of the cells?
Imagine that these are the two packs, each has 4 rows of 13 cells in series (top to bottom) and all 4 rows are paralleled.
The gap between the two packs for each cell will be connect with an external wire.
Each pack will be 10.4ah which paralleled means 20.8ah (Samsung 26F cells which are 2C) and have about 40A max draw, let's say 50A if the controller is 45-50 in those scooters that I'm messing.
What do you think will be the amp "movement" in the wires that I connect to parallel each cell in series?
