LI-ghtcycle
Hello!
I'm really curious why this is, if I understand correctly, the cogging that is felt while riding a DD E-Bke, is caused by permanent magnets inside that are generating resistance because the magnets' are N to S polarity and magnetic attraction is making the stationary side and the spinning side try and hold the wheel still while not under power.
Now, what would be different with one DD vs another that would make one have significantly more cogging than another?
I have tried a few different DD's out there, and I have not tried a X-light 530X monster hub motor, or one of the other DD motors I hear people talk about with such terrible cogging that they are practically impossible to ride when not under motor power.
I have used Aotema and 9C DD's the most, but I have casually demo'd in a parking lot a few others, and I haven't ever experienced this excessive cogging, and granted I pedal a lot, so I'm not as adverse to pedaling, but since I have been riding almost exclusively un-powered pedal bikes for the last month to 2 months, you would also think I would be extra sensitive to when I WOULD have a DD motor cogging.
The only time I have ever experienced this is when I am assembling a kit and try to rotate a hub motor and the leads from the motor are loose and touching each other, so I wonder if this means it's a controller issue more than the type of magnets used?
The other reason I ask, is because earlier generations of DD hub motors seem to have lighter gauge windings, less weight, and I'm wondering if they might also have less cogging, I don't really know because I haven't been able to do any long term testing on a newer generation of say a 9 X 7 9C motor but I'd like to know what you all have experienced.
Thanks!
Thanks!
