Basically true.
There are various Android apps that you can download that will allow you to change your sampling rate on the camera.
With this you can tune in the flickering. See a harmonic of it.
... What most people forget about power transmission is that it happens at an extremely high voltage. Thousands of volts, tens of thousands of volts, even megavolts.
That's actually what allows you to use small, cheap, poorly conducting wires. Ohm's law proves it to be true.
You can prove it with an efficiency calculation. Power generated, power available at the other end, power cooked off in the cabling.
In every scenario you want to minimize current. As current converges on zero, efficiency converges on infinity.
Layman who don't actually understand. . . Will argue till they're blue in the face to the contrary. And nearly every case I found the flaw and their argument to be....
They mix up the voltage at the source and load with the voltage developed over the cabling.
nobody bothers to argue with them cuz if you just write the formula down it becomes instantaneously obvious.
You absolutely have to have a rock solid foundation in algebra. to not be able to do basic algebra is to not be able to understand the most fundamental things
The human mind wants to skip around
Especially when a given label can mean two different things.
algebraic equation is what allows us to prove this unequivocally and beyond any doubt or argument. Misconceptions persist. . . Mostly because it is so obvious (once properly written down) that it is accepted as fact.
... The cool thing is that you can prove it too!
You can actually prove it with nothing but thermometers... So Mercury trapped in a fixed volume... You don't even need a voltmeter
-methods
