Why not heat my house w heat lamps?
markz said:
X
So depending on the minerals or other inpurities in the water source for the humidifier, could put more particulates in the air.
https://www.iallergy.com/pages/humidifier-faq
What is white dust, and should I be concerned about it?
White dust is a byproduct of minerals found naturally in water, which can sometimes be released into the air during the humidification process. White dust, which can be a nuisance but is not harmful, may settle on surfaces and furniture near the humidifier. It is easily cleaned just as you would normally dust. Warm moisture (steam vaporizers) and evaporative cool moisture humidifiers do not release any white dust into the air. The only types of humidifiers that can potentially release white dust are ultrasonic humidifiers and cool mist impeller humidifiers. Many ultrasonic humidifiers come with an optional demineralization cartridge designed to trap minerals before they can become airborne, thus reducing white dust. You can also use ultrasonic humidifier water treatment to reduce white dust. The amount of white dust you may experience will vary depending on the mineral content of your water supply. If white dust is a concern, you can use distilled water in your humidifier instead of regular tap water. Distilled water has very low mineral content and will not produce white dust. For other types of humidifiers, using distilled water will also reduce the amount of time you will need to clean your humidifier, and will help prolong filter life.
Wife's father had a ultrasonic humidifier. White dust all over his apartment.
With my humidifier, the minerals stay in the tank. Should clean it at the end of the winter. I am lazy and clean it in the fall.
marty said:
Hummina Shadeeba said:
marty said:
Increasing the amount of humidity in the air makes ya feel warmer at a lower temperature.
i read humidity makes you colder if the temp is cold.
https://lhtcooling.com/why-does-it-feel-colder-when-its-humid/
https://www.brennanshvac.com/articles/humidity-temperature-strange-link-know
Think you might be thinking if your clothing gets wet. Like in the rain. Or hot and sweaty. Yea you will feel colder.
i hadnt thought of it before you said it and was curious and started searching and it seems humidity in cold air will make you colder
marty said:
markz said:
X
how do the minerals get airborne? ill boil water in a pot and will be left with minerals in the bottom of the pot and I assumed only the water being able to evaporate will get airborne. i thought you could evaporate water to purify it
https://www.rookieparenting.com/evaporation-distillation-water-science/#:~:text=This%20process%20of%20using%20evaporation%20to%20purify%20water,points%20or%20boiling%20points%20much%20higher%20than%20water%E2%80%99s.
