ZeroEm
The US government was working on a Clean coal plant in South Carolina USA. 2 years ago I read the cost was triple the average for a KW. It seems to have disappeared. Now all Coal in the USA is clean and beautiful.
That would no doubt be one of the futile attempts at CCS (CO2 sequestration)The US government was working on a Clean coal plant in South Carolina USA. 2 years ago I read the cost was triple the average for a KW
There are over a TRILLION tons of KNOWN , PROOVEN, coal reserves in the world, most of which is high quality Anthracite.The latest problem with Coal is the best coal has been mined,…….
Every ton of coal burned creates 2.6 tons of co2 (actually it releases co2 removed from the atmosphere by plants, as carbon, and locked away millions of years ago)There are over a TRILLION tons of KNOWN , PROOVEN, coal reserves in the world, most of which is high quality Anthracite.
With current consumption at less than 9 billion tons/ year, its obvious that there are many years of quality coal supplies available
…..even ignoring the unquantified coal deposits known to exist.
List of countries by coal reserves - Wikipedia
en.wikipedia.org
They also don't include any of the contaminants contained in the coal that are then expelled into the air during burning.In fact, it's insane to keep burning coal, those numbers don't include the energy burned in extracting, refining and transporting coal.
Or dumped out on the land and waterways.They also don't include any of the contaminants contained in the coal that are then expelled into the air during burning.
But renewables are not storable in a large scale yet.That's stupid, especially when PV energy is much cheaper.
It all seems confusing and it is supposed to. There are the people who want to clean up things. The people who want to misdirect you and the others who don't care as long a they can make a buck.But renewables are not storable in a large scale yet.
This paper suggests to store the surplus in natural gas tubes. To be honest, I don't understand the idea. Use the surplus to compress natural gas to 250 bar in pipes.
And then?! Should the relaxation to standard pipeline pressure bring back the energy?!
What would be the efficiency of this method?!
Strategic Reframing of Seasonal Energy Storage
Imagine a farmer who sows his fields, nurtures the crops through months of hard work, then — during a particularly good harvest — simply…medium.com
Compressed Natural Gas Energy Storage
Learn more about sustainable technologies and ways to prevent pollution with our sustainability events.www.istc.illinois.edu
Compressed Air Storages are about 50% efficiency, up to 70% if they are used adiabatically. But normally, the heat, that is generated when compressing the gas can't be stored seasonally to use it during decompressing several month later....
And you can't use it for heating, as the surplus will be generated in summer, when there's no need to heat buildings...![]()
So how do explain that every country that has installed significant Wind and Solar generation capacity, has experienced higher electricity costs ?That's stupid, especially when PV energy is much cheaper.
…which can be/are removed using existing technologies in modern coal fired generation plants.They also don't include any of the contaminants contained in the coal that are then expelled into the air during burning.…
I will take a stab at it. We are using/consuming more KW. Here in the USA AI and bit Coin require buildings full of servers to do the work. All of them Servers require cooling. I have not kept up with how many are moving into Texas but they are using up any extra KW we have and demanding more. If you are interested I can to some research on it and explain why cost are rising. In San Antonio our rates went up the past two years. We were going to get a rate hike this year but CPS found a way around it. The future is higher prices and Renewables, Gas and Coal have nothing to do with it. Coal is going to the way side because of cost. It's cheaper to pump Natural Gas thru pipe lines, in the panhandle of Texas the wind blows everyday as on the Coast. We have a lot of Bright Sunny days here too. Figure it out.So how do explain that every country that has installed significant Wind and Solar generation capacity, has experienced higher electricity costs ?
note: the answers are obvious to those with an open mind.
More of your obfuscation.So how do explain that every country that has installed significant Wind and Solar generation capacity, has experienced higher electricity costs ?
More self dillusion…More of your obfuscation
PV is getting more money invested every year, coal is getting less, worldwide.More self dillusion…
demand has not changed significantly, in many cases it has reduced due to the migration of manufacturing industries to Asian countries, and also the adoption of roof top solar In western societies.
Few countries have opted to bury power lins due to the huge additional costs and Hydro generation has never been a major contributor in most countries to have any impact on costs.
AI , Crypto, etc ?..?,..power costs began increasing since Wind and Solar were first introduced in the 1990s, before either of those , or even the Internet, were established, let alone in common use.
For certain there are many more grid connections, since that is a essential requirement for the new locations required to install Wind and Solar facilities far away from the demand centers where traditional coal and gas generators are located.
(Maybe you would like to discuss the costs of off shore wind connection lines ?)
No, ..the real cause of increased cost of electricity when Wind and Solar are used is the need for impracical amounts of storage, huge over capacity of installed power generators, and the requirement ot maintain 100% thermal generation for backup to prevent blackouts on windless periods ( becoming known as “Wind Droughts”,.. which can last days or even weeks)
The only reason why Coal plants are not being installed in the West is the insane (impossible) political drive to “Net Zero” which makes investors wary of future financial returns,….which are garanteed with Wind and Solar investments.
That is not a situation in countries like China, Russia, and other “Eastern” nations, continuing to build coal generatorsin preference to the intermittents.
i already did…PV is getting more money invested every year, coal is getting less, worldwide.
Explain that, if coal is such a good deal.
which 3 regional grids are you refering to ?Most of the big new grid connection expenses are to allow long distance transmission, between the three regional grids, a long overdue fix.
I did not say that !"Eastern" nations are not investing in "coal in preference to intermittents *, that's a lie.
No, its a fact,..for. the reasons stated…*power costs began increasing since Wind and Solar were first introduced in the 1990s*...implying that it was wind and solar that caused those increases is another lie.
All these things are right. But your conclusion is wrongovercapacity requirements
storage requirements
extra grid connections
Need for back up
Smells like boondoggle to me. Like some recent engineering graduates haven't kept their eye on the ball of benefits needing to outweigh costs.thinkgeoenergy
Here is another story on Geothermal. They are doing a test Well just north of Austin Texas. Using high pressure Co2 as the transfer medium to run high efficiency turbines.
Which conclusion ?…All these things are right. But your conclusion is wrong
Staying at an overcome technology has never worked in this world.
… but yet you do not recognise that exact senario for Wind or Solar ?"Free energy" isn't free if it bankrupts you getting to where you can use it.
I dont see the connection with coal,…but that was an old article and meanwhile back in CA..states-banning-new-gas-powered-cars
This should help bring back Coal!
Early last month, 35 House Democrats voted alongside their Republican colleagues to kill a law in California—a version of which has been adopted by 11 other states—mandating that all new car and truck models sold in the state would have to be “electric or otherwise nonpolluting” by 2035. The Senate later followed suit, with Michigan Democratic senator Elissa Slotkin breaking ranks to join the GOP in ending the mandate.
