Lebowski. Please understand, I respect your abilities.they are responsible for me coming here. I've read your motor threads in depth. I've started on your controller threads. If I get my motor to the point where I believe I can build it I can see myself coming to you to purchase one of your controller chips. What comes below is the way I have understood the world to work since college. There is to my eyes nothing even vaguely controversial about it. And, from my viewpoint, it is all as clear and simple as the nose on your face.
Throughout this saga I've been expecting someone to step in a support my stance. To say, you guys are conflating your terminology. Browser is obviously correct. That hasn't happened and I am astounded that it has not.
Lebowski said:
Ok, answer this question then. You've managed to build a brushed motor with zero backemf.
I've never said you could ever build a motor without back-EMF. Indeed, I've said several times you cannot avoid it.
Lebowski said:
The question to answer now is, where does the mechanical power come from ?
The torque in a motor comes from the EMF; by way of the magnetic attraction between the field it induces in the coils, and the permanent magnets. There is nothing controversial about that bit right?
Now, assume the motor is stalled, (car on a hill) the EMF (battery voltage) is flowing in the coils. The coils are attracting the magnets.
The force (attraction for one phase, repulsion for the other excited phase) between the coils and magnets, constrained to one degree of movement by the axle, is the TORQUE.
Nothing has moved yet, so no back-EMF can possibly exist, but the force is there and if you let off the handbrake in the car, that force is enough to prevent the vehicle from rolling backward.
Even if you have not supplied enough EMF to allow it to overcome the weight of the vehicle, it passengers, friction and gravity to allow it to move forwards, the motor is consuming power and the resultant torque is preventing you from rolling backwards. EMF is flowing through the coils, the field they produce is attracting the PMs, torque (maximum torque for the supplied EMF) is being produced.
But nothing has moved. So the coils have not experienced a change in the magnetic field from the PMs. No change, no induction, no back-EMF. EMF, but no back-EMF.
Only once you start moving do the coils experience a change in the magnetic fields from the PMs, and only then does back-EMF start to be generated.
But ONLY AFTER the EMF has produced enough torque to cause the motor to start revolving. Torque has to exist BEFORE back-EMF can be produced, thus it cannot be responsible for its existence.
And at low speeds, the amount of voltage (thus current) produce by the slowly moving magnets is tiny. Not enough to overcome friction, gravity et. al, (Which is a good thing because it means that most of the EMF is generating torque; and because if back-EMF was producing torque it would be driving the vehicle the wrong way!)
As speed builds up, the back-EMF produced increases, because the rate of change of the PM magnetic field increases, and that back-EMF reduces the effective voltage flowing in the coils, so the attractive/repulsive forces are less, and the torque produced reduces.
Eventually, the speed of the motor increases to the point where the back-EMF has risen to match and exactly oppose the EMF from the batteries, and no more torque can be produced and the maximum speed for the motor has been reached.
Reach a (steeper) hill, and the vehicle slows down. Because the motor rotates more slowly, less back-EMF is produced, so more torque becomes available. And, given enough EMF, you make it up the hill.
