Peter Brigg
Established
I bought an Electric Wolong outboard and the first battery supplied did not work. We got another battery under warranty and it has worked well. The supplier did not want the battery returned and I am considering opening it up to see if there is some simple fault ie a connection and the battery can then have a use. I have worked with lithium ebike batteries and I am prepared to see if it can be salvaged. Being an outboard the unit is sealed to prevent salt water corrosion. Has anyone attempted to open up this type of battery. Any advice is appreciated
