Mikeorrison
1 W
- Joined
- Jun 25, 2022
- Messages
- 55
So if you get a control box that comes with joulette connectors on it. How do you find the Ignition wire?
Do you see any orange wires?So if you get a control box that comes with joulette connectors on it. How do you find the Ignition wire?
I came with the jewel connectors, so you can't see the wires. It's a kt 36/48SVPR-ffF101LDo you see any orange wires?
Chinglish to English Translations (work in progress)
As suggested before, it might be best for you to get someone to help you type your posts and help upload pics, to reduce your frustration and stress level. It’s easier to help you without the emotion muddying up the facts, when there’s little punctuation to start with. If you can’t post a pic, a link or any f***** information about your d**** controller would help.
- Electric Key Lock/Key Switch/Electric Door Lock/Ignition/Power Lock : Controller on/off; usually applying battery level voltage to the signal wire turns on the controller (frequently a thin orange conductor).
Thank you for your information. Which I tried to find, but couldi'm trying to figure out which one of these coming from the I'll keep you posted on the results. Thanks again.Do you see any orange wires?
I'm 2 years into my learning and well. It's just saying everybody's different and so it's not easy to. And I tried finding that pin out diagram but I looked again but it's loose it to me. I'm glad it's easy for you to find online. But apparently not for me.As said above you need a 1T4 or 1T5 connector cable to join the sensors/display to the controller.. "E-bike 1t4 cable" or "e-bike 1-5 cable" via google should get you there.. the keywords 'julet' and 'pinout' will via google get you to the pin designations for the controller but a $5 cable is the best solution..
Similar exposure to ebikes this end, the odd occasion i have looked for the pics/specs for the controller julet pinouts my limited google-fu has led me to pictures posted on this site dating back some timeI'm 2 years into my learning and well. It's just saying everybody's different and so it's not easy to. And I tried finding that pin out diagram but I looked again but it's loose it to me. I'm glad it's easy for you to find online. But apparently not for me.
