One foundational aspect of my drive system is a 1 and 1/8 inch OD bearing.
Here is a quick sketch of the drive unit. You can see how it can be laid out or folded up, or any position in between.
The shaft centers are 3 and 1/2 inches apart for the secondary drive and the motor is mounted on a slotted plate for belt tension adjustment.
There will be various mounting tabs for it that are not shown. But, this gives you an idea of the actual drive. This was drawn on 1/4 inch square graph paper at roughly 1/2 scale.
I just realized my reduction drive drawings are off a bit. The motor plate shows (in the sketch) to be 7 inches long. That is not correct. The motor plate will only be 5.5 inches long.
The large belt pulley is 4 inches diameter and the #25 secondary sprocket is nearly 5 inches in diameter. This drive will be setup as 16 to 1 to begin with. I can go down in motor pulley and small secondary a few teeth each for a 24 to 1 ratio. Any lower and these parts will be larger.
Bear in mind, the photograph (SKETCH) shows very large pulley and sprocket. These are the absolute maximum size for a very drastic reduction ratio. Most drives would use much smaller pulleys and sprockets.
