Yet another Noob Question for HUB Help
elvill
Eugene, Oregon
I purchased a budget hub kit for GF for holidays. 36v500w not great but cheap… Connected everything but PAS, brakes, and light (which is not ON switch). Plugged in battery and throttle lights lit up but no hub movement with throttle twist.
Everything seems to be connected correctly, Do I have to 'remove pas' instead of just keeping it unplugged? I'm sure the brakes don't have to be plugged in correct?
Any help wold be appreciated :)
Some throttles have an on/off switch on them and it has to be connected and in proper position.
On switch is on throttle, clicks lights on assumed it work allow throttle to turn motor.
looks like I could do procedure to check combos of wires…
too bad they came connected plugged in
What voltage battery?
Most likely, your controller is dead out of the box. Or, you just haven't found a loose connection. Look to be sure all the pins in the plugs are not backing out of the housing.
