Here's my daily ride. I don't have a before pic as I built it from the frame up as an E-Bike. Here are it's main features:
- Heavily modified Chromoly Single Speed Track frame
- Alex DH-19 wheels with Schwalbe Energizer Plus tires (700c x 35mm)
- Lyen 6Fet controller with Low/High switch capable of handling 36v - 90v
- Mac Motor
- Custom CAD drawn, laser cut Carbon Fiber battery box
- Integrated On/Off switch
- Integrated 3 speed switch
- External "Powerkey" which disconnects the controller from the Battery pack when not in use
- Handlebar mounted digital gauges. Voltage(Blue), Motor Temp(Red)
- Aluminum Wire covers
- Custom wiring from the throttle to the motor
- 10awg/8awg Phase wires with 4mm connectors for easy rear wheel removal
- 10awg Battery Wiring Harness with color coded APP 45A connectors
- External Charge Port (1)
- External Balance Ports (4)
- Quick release mount for CA
- Cyclometer hardwired to rear wheel
- Zero (0) Zip Ties
- Zero (0) Duct Tape
I've configured it to run on several variations using Lipo batteries. I've tested it at 37v, 44.4v, 52v, 74v, and 88.8v ranging from
370w/hr - 444w/hr. 20 - 30 mile range. 1 - 1.5hrs charge time (10A)
37v = 20mph, 88.8v = 40+mph
370w/hr = 44.8lbs, 444w/hr = 46.4lbs
Tony
www.snelheidcycles.com
