Zenid said:I have a question about the resistors on the back of the board. I've got them to squeeze into the box nice and snuggly, so that the resistors make good contact. However a few of them got the chalky layer scraped while getting them to go in (some were a tight fit) and I see traces of the bare metal of the resistors exposed in places.
Could this offer the danger of shorting with the box casing, or are the resistor cases fully insulated from whatever it is inside that does the resisting?
Yes. You want to make sure there is no electrical connection between the case and any of the resistors. You can measure with an ohmmeter from the case to each tap wire and make sure there is no continuity. I have not tried scraping off the outer layer to see what lurks underneath, but if you see metal, that would usually be a problem.
If any of the resistors are shorting to the case, the solution would be to add a layer of insulation between them and the case. Kapton tape is the preferred stuff. It can be stuck to the inside of the case where the resistors touch. Silicone heat sink pad material will also work. Ghetto approach is to lay down a layer of silicone glue over the resistors and use a flat piece of plastic or metal that's been greased as a mold to make it flat. Once the glue hardens, remove the mold. Push the resistors all the way down to the board before gluing to leave some clearance for an insulating layer.
Hopefully none of your resistors are actually shorting to the case and none of this will be necessary.
I guess it would be a good idea to round off the sharp edge of the case before sliding the board in and bend the resistors down enough so they aren't too tight going in.
