safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Zero X: Or Why Ebikes are not Emotorcycles...
http://www.zeromotorcycles.com
The Zero X accelerates from 0-30 in under 2 seconds! The Zero's electric motor delivers over 20 horsepower and similar performance to a 250cc gas powered off-road motorcycle. With an electric motor you get 100% torque at all times for instantaneous throttle response and incredible off-the-line performance. Because the Zero is so amazingly light, it's power-to-weight ratio is unsurpassed by anything else on the market.
Discussion:
Given that the Zero X already blows away most everything it makes little sense to be thinking about ebikes that use this kind of power. (it makes the hub motors look rather silly)
Isn't the Zero X the perfect argument for limiting ebikes to 750 watts?
If not 750 watts then what?
How would would know what the "ebikes" were compared to the "emotorcycles"?
Discussion:
