The bike droped weight by 10 pounds
.. Swaped 5403 by MXUS 45H 3T
It is now 105 pounds
When adding the front wheel ( + 25 pounds ) and the second controller +2 pounds total will be 132 pounds.
But!!!... when i will remove the actual 1.8kWh Farasis cell pack ( 30 pounds) and will swap for the LONESTAR 150C lipo pack it will drop again to: 12 pounds
In total the bike should weight exactly 114 pounds if using the 80kW 9Ah pack and 108 with the 40kW 4.5Ah pack..
I estimate the total hp at the wheel to be at least 30hp according to my past experience and extrapolation.
Me and the bike should weight about 275 pounds.
This mean about 12.8sec on the 1/4 mile... BUT i am limited in max speed to about 130-140km/h.
Well,,, the estimated max speed is difficult to calculate because the Adaptto have the field weakening witch boost speed by about 20-30% compare to the ebike simulator prediction with a normal 100% PWM controller no field weakening.
According to the ebike simulator torque curve, the gain in speed by adding a second controller and motor for 2x power at the wheel at high speed is about 13km/h.
with my 9kv 5403 i was able to get 116km/h on 22s(not power limited). Now on 20s and a 12kV motor max speed should jump to about 140km/h.. YEAH 88 miles per hour !!
and with dual motor the speed gain is 13kmh at 86km/h and probably about 4-5km/h at 140 witch bring the max speed to an estimate of 145km/h!
Now add a resonable derating to that and you get about 130-135kmh... still not bad but just wnough for a decent 1/8 mile time!!
Doc
