Milou
1 W
Hi: A while ago I bought Serengeti Panther Electric Scooter with the following Specifications:
Motor Type: 500-Watt Electric
Brake Type: Front and Rear Hand
Number of Wheels: 2
Battery: Rechargeable lithium-ion battery
Charger Type: 110–220 VAC UL-Approved
Average Recharge Time: 6 Hours
Top Speed: Up to 30 mph depending on rider's weight, road conditions, and other external factors
Distance: 50 miles per charge depending on rider's weight, road conditions, and other external factors
UPC: 8 94836 00253 2
Motor: 500 Watts
Battery: Lithium-Ion
Battery Life: 1,000 Recharges
Top Speed: 30 mph
Ride Time: 80 Minutes Per Charge
Charge Time: 5–7 Hours
Charge Input: 220V or 110
Charge Output: 48V/3A
Unit weight 175 lb.
Long story short, it has a defective battery/charger? Will not charge beyond 32V. The scooter will not work. I also suspect the controller (scooter only worked once and quit within a few seconds). In any case, I would like to get this thing running even if I need to replace some of the equipment. Given I am also a tinkerer, I would like to increase the motor performance for hills. We have several hundred yards of roads that climb steeply. At first I would like to start out with already made kits. Else, I will do my own piece meal modification with all your help! First, some quick first thought, expert suggestions, needed from all you guys??? Thanks in advance. Regards JJ
Number of Wheels: 2
Motor: 500 Watts
Top Speed: 30 mph
Unit weight 175 lb.
