A
Anonymous
Guest
waste
Malcolm said:The simplest way to mimic this effect is to use a Bionx hub motor, which has strain gauges built into the motor. These sense how much torque you're applying through the pedals and adjust the power to the motor accordingly. Unfortunately it's a low-power system (350W max I think) so you're not going to get to 50 mph.
Here are some more threads on the subject:
http://endless-sphere.com/forums/search.php?keywords=torque+sensor&terms=all&author=&sc=1&sf=titleonly&sk=t&sd=d&sr=posts&st=0&ch=300&t=0&submit=Search
novembersierra28 said:Believe it or not, using cloth-tape and superglue, and welding a little bit worked. I refilled all the bearings and now it doesn't let me down.
novembersierra28 said:Why does one need a BMS apart from to charge the battery? surely the BMS's are limiting the current...so by by-passing the BMS I could attain peak currents of 300a, the 20ah packs will do 600amps? Does anyone know where BMS's that do 300amp peak are got?
any help is appreciated.
novembersierra28 said:I had a look around for 20ah POUCH cells, very interesting..but very expensive.... the 15ah alone cost 1018 USD + shipping + charger + BMS....
and the BMS wouldn't be up to this ammount of power (300amps...it'll peak at 60amps). I need more power as this thing is doing EXTREMELY WELL but the acceleration is sagging...I feel there is more that it can give...it's just 'trapping' that power into jaw-wrenching acceleration. The 300amp controller is pulling 150amps Peak before 'juddering' (voltage sags below 36volts).
amberwolf said:One way you could do it is a single hall sensor on the frame, and a bunch of magnets around the granny ring. As each passes the sensor it sends a pulse.
Use an op-amp to integrate that pulse into a voltage level. Another op-amp to scale that voltage level as needed for input into a voltage-to-resistance converter.
The V-R converter is easily done like this:
http://www.maxim-ic.com/app-notes/index.mvp/id/3284
Just use the p/n for the 5K version. It's output is used instead of your handlebar throttle.
If you want both of them to work, then use your handlebar throttle as an input to another op-amp to let you scale it's input to that circuit, and feed it into the V-R converter in parallel with the first one, both with series resistors to prevent feedback of one into the other.
If you're not handy with electronics, it'll take you a bit of time to find all the pre-made circuit diagrams for the pieces of this around the web, but it's all already there. There are links in Ypedal's recent thread about learning electronics that have some of it, perhaps all.
The magnets on the granny ring/sensor on frame can be replaced with a rolller on top of the pedal chain, too, but it doesn't work very well with the motor power running thru that chain, too.
a bit. There are other ways to do it, but this one would definitely work, and all the individual circuits needed are already available on the web, along with calculations for resistors/capacitors to do different things with them (kinda like the 555; it's all been done already, by so many, that info is easy to find). All that's needed is to hook the circuits up to each other and your sensor and controller, and voila! Or, at least, it's supposed to work like that.novembersierra28 said:ah....complikated.
Exactily.so If I get this right, an op-amp changes the pulse into a voltage level which in turn changes through into resistance.
