A
Anonymous
Guest
waste
My andersons (visible in the pic of the bike) take any arcing during connect (shoudln't be any during disconnect). Then I have a circuit breaker on battery negative to disconnect the whole pack from everything. if I need to, even if the run/stop switch and the keyswitch won't turn it off for some reason. It's on the other side of the bike, right near the top of that top battery.novembersierra28 said:Thx,how do you avoid arc'ing then?
Note the numbers molded into your controller:novembersierra28 said:where do I wire the keyswitch to? (there are three tabs. which tab do I wire this up to? the one next to B- or the one farthest below B- ? )
amberwolf said:Note the numbers molded into your controller:novembersierra28 said:where do I wire the keyswitch to? (there are three tabs. which tab do I wire this up to? the one next to B- or the one farthest below B- ? )
Then refer to the post I made earlier in the thread on how to do it. Until you wire it with at least something connecting as described, even if not a switch but just a straight wire, the controller won't even work at all. So if you have already used it, you've already *had* it wired up right.
Well, I did list which ones go where by number :novembersierra28 said:Thanks amberwolf, I've copied what you said verbatim, but, if you could possibly refer to 1,2,3, (which one connects where) then that would be very helpful, as currently I only have a vague idea of 'center' tab if you see my point.
I don't recall talking about a "center tab" anywhere, though.Amberwolf said:--The three little tabs:
1--keyswitch, one side to here and one side to B+
2--"top" side wire from throttle pot.
3--center wire from throttle pot.
Have to swap the beer for Dr. Pepper, though. Unlikely I'll ever get to travel, but it's a nice thought.Thanks again, If I ever see you in the UK I'm buying you a full meal and beer!
Each 1204 is a specific model. As I said in my first post attempting to help you, mine is a 1204. Specifically, it is the 1204-410, which is different from yours. I don't know what yours is, but all the manuals are on the Curtis site if you did not get a paper copy with it (I didn't). If they're not there for any reason you can ask Curtis for the specific one for yours. Some manuals cover multiple models because they are all the same for their wiring and use.novembersierra28 said:My curtis 1204 series controller seems to have several different manuals, they are complicated. Is your controller a 1204 series?
You'll have to follow what I already said:If you could possibly start with Magura. The only thing that it shows , is when I use the brown cable, and blue cable, that's when twisting it shows a reading. (the multimeter 5k).
I know that according to the magura website, Wiring: blue - throttle high, brown - wiper, black - throttle low.
Apparently you do have the throttle wire color diagram, so follow that for which is which. If you're not sure, use the meter.amberwolf said:--B- is pack negative.<snip> Throttle pot also has it's "bottom" side wired here.
<snip>
You'll have to use a meter to tell which wire is which on the throttle, unless you already have a diagram that tells you which color is which.
Not be mean, but I already said it as clearly as possible.Where do I wire the cables of the batteries? positive goes to B+ I assume? negative goes to B - ?
amberwolf said:--B+ is pack positive. Motor also has one side wired here. Keyswitch also has one side wired here.
--B- is pack negative. Mine has a breaker between the actual batteries and the controller. Yours will have the contactor (and maybe a breaker too, or a fuse, would be a good idea). Throttle pot also has it's "bottom" side wired here.
No, it has nothing to do with arcing. As for the positive vs negative, that depends on the controller design and type; it could be either one or even neither. Yours (and mine) happen do to it by modulating the negative.so essentially a controller regulates motor speed by sending out fast electric signals USING THE NEGATIVE , not the positive, is this right? that's to prevent arcing?
All the precharge resistor does is prevent arcing across a contactor, power switch, charging leads, or battery plug in leads, depending on which one you use it for. The way it does it is by providing a low-current path to connect whatever it is you are connecting, before you actually make the full connection.Fourthly: If I have a standard switch (not an anderson switch), will I be able to use 'Kettle leads' if I were to connect the precharge resistor first? will the precharge resistor stop ALL arc'ing?
YAY!novembersierra28 said:I'VE DONE IT!
IT WORKS! I can now control the motor and it works terrifically!
No, the killacycle uses A123 batteries (a LOT of them), not lead-acid. SLA the size of yours can't likely put out the full current that motor can draw without serious voltage sag.the only problem is, I think the controller is programmed for a 'low' setting as I am getting a 'judder' when i'm 'giving' it some....this leads me to think that the batteries are crap...but then with the killacycle the guy uses the same batteries...so what have i missed?
You would need to compare the data sheets for the two brands, and see what they are rated at for higher current ratings. I know PowerSonic has this data in their spec sheets, you'll need to check with Ultramax to see if they do. If not, you can at least compare the PS data sheet with your actual experience of the UM.novembersierra28 said:Do you think if I upgraded to POWER-SONIC 18ah batteries I'd get a MUCH better amp draw than these ULTRAMAX's? I'm thinking that could be my next upgrade?
Stainless Steel Hose Clamps. I use them to hold my SLA in CrazyBike2's frame. If you can't find ones long enough, use multiples in series. Just be sure to keep them clear of the battery terminals.Do you know of any 'zip-tie' like instrument, (nothing short of a belt) that I can loosen up and 'zip-tie' back up when I want to change the batteries round (when they're dead)..
I think I know what's happening. I have not soldered the lugs onto the cables, and have left the 'standard' 250amp cables in place, leading the whole setup to probably have some unusual 'wiring' in it's midst. I should probably take the wiring up to 300amp wire eventually. it's also probably necessary to solder those lugs on. I've been shoving aluminium foil into the lugs to make sure I have a good connection but I highly doubt that that is a good way of crimping (any thoughts on soldering vs aluminium foil?)
A CA isn't required, depending on the currents you expect to be drawing. Under 130A (burst) and probably 80A continuous, you can use one of the cheaper alternatives like the WU, or even the WU ripoff Turnigy Watt Meter. Both of those will do the job of helping you figure out the power you're using, and since you have a brushed motor you can even directly measure either battery *or* motor current. Well, the motor current could be so high it could melt the shunt, with the one you're using. But with the CA and an external shunt made for high currents, you could measure however high a current you like.I do not have a cycle-analyst, it is an expensive piece of kit ....
novembersierra28 said:liveforphysics said:Those aren't going to do jack squat for you.
Those are 4x 20Ah TS cells in a plastic case.
If you want to run your device without it cutting out from low-voltage input to the controller, you're going to need real batteries.
Like Amberwolf all ready said, A123 or LiPo are the only affordable options out there for something light enough to work on a bicycle, yet able to deliver the current needed to run an E-tek properly.
Hi there
That's a downer, it's a shame the 171GBP lifepo4's in a plastic case won't work. A123 it is then.
Is there anything that can help me build this battery pack? I've found 50pcs for 200 dollars... http://cgi.ebay.co.uk/New-Lifepo4-A123-18650-1000-1100mah-battery-Cell-50-Pcs_W0QQitemZ320514055633QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4aa0205dd1
That's not odd at all. The current requirements would be no different with or without the controller--in fact, without it the surge currents would be even higher, and the juddering potentially even worse.novembersierra28 said:I think what is really odd is...it juddered the very first time I used it?
If you hadn't even charged them yet, I would definitely expect you to have trouble getting enough power out of them. No battery can be expected to come with a totally full charge on it. It's up to the end-user to provide the full charge.ie, I had NEVER charged these batteries, they came stock out of the factory plant and I plugged them straight in without charging them or anything..... I'm fairly peed off with ULTRAMAX's and hate them accordingly.
PS are probably better than UM, based on the specs you list. But to be realistic, you'd have to compare specs at the discharge rates you are actually using. To find that out, you still need to measure what current you are using, average and max. Until you know that, it's hard to compare.I suspect my next upgrade will involve POWER-SONIC batteries once these batteries give up the ghost...as the LIFEPO-4's are way out of my budget.....
